Question about Dayton Heating & Cooling
Whats up with the thermostats for model #3UG73D as this is the third year in a row I need to replce it?
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
May 24, 2017 | 2003 Ford Expedition
2004 ford expedition: changed battery, now rear seats will not go up or down. One is up the other one is down. They were working fine before the battery was replaced. Wifes car need to fix, she is...
Call the dealership and ask them how to reset the electronic on your Ford Expedition after changing the battery. Anything else is happen? Maybe like the radio wont turn on, hit the turn signals and the windshield wiper turn on. ***** things happen after replace the battery. I know what it is, it the darn wigits. GB you....stewbison
Aug 21, 2011 | Ford Expedition Cars & Trucks
My whole house is heated with electric baseboard heat,1 thermostat keeps blowing out.have replced 3 times in 1 year
You will need to put an amp meter on one of the power lines to see what the element is drawing for amperage. It is amperage that produces heat and will shorten the life of any switch including the thermostat. Compare your findings with the rating of the thermostat.
Mar 13, 2011 | Heating & Cooling
I need the 3er road seat , were can i find it
Your best deal will be found at your local late model junk yard. If that doesn't work google that **** pardon the french ( 3rd row 2007 gmc yukon/tahoe/) you will get some ebay hits,craigs list exc i am sure that a suburban or any general motors full size year appropriate third row will work
Nov 30, 2010 | 2007 GMC Yukon Denali
I have a 3ug73d heater I would like to put a real thermastat on it.How do i wire it.
is this a baseboard unit? the thermostat kit has four wires - a black and a red, a black and a red. for 240 volt operation, both line wires go on the two blacks and the heater load goes on the red wires
Oct 13, 2009 | Dayton Heating & Cooling
Can you tell me the location of the cigarette lighter fuse. I got no power from the socket Toyota Prius 2 year 2001 model
facing the steering its just to the left of the collum under the dash its the third fuse in the middle row i believe
Apr 22, 2009 | 2001 Toyota Prius
Mounting third row seat in 2008 Suburban 1FL, LS 1500 - Fleet veh
I drive a 2008 Suburban LT and my company has a true work "fleet" suburban. The only difference between these two that I have is the back of the fleet vehicle has a thick rubber mat in the back with no seats. After removing the black mat I found that the channels and rods that the rear seats clip into are present. The third row seats are installed by clipping them in no bolts or tools are required.
Jan 20, 2009 | 2008 Chevrolet Suburban
Thin Black Vertical Lines 8 in each row, 9 rows. Whats wrong?
Hope its under warranty! your DLP chip itself most likly is bad or If you are very lucky.. its only dust on the DLP chip,,
Time to take it to the repair man.
Feb 09, 2008 | Samsung DLP HL-P5663W 56" TV
Heating & Cooling Logo
41 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
