Question about Redmax Garden
How to check coil on redmax leaf blower - Redmax Garden
5 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Toro leaf blower has spark but will not start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Just let me know if you need further assistance.
Jim
Posted on Jun 21, 2009
  • 343 Answers
SOURCE: I have two craftsman leaf
With the plug removed but connected to the spark plug wire if you pull the cord do you get spark? If so try pouring a cap full of gas in the spark plug hole and reinstall the plug and wire and try to start it. If it starts and stalls then you are not getting gas thru the carburetor. Check the fuel filter in the tank. Also check all the fuel lines and the primer ball and see if they are cracked. Also check the carburetor to see if the choke is opening and closing.
Thanks for using FixYa
Posted on Aug 19, 2011
SOURCE: Why is my redmax hbz2610 leaf blower bogging out
The fuel mixture adjustment screw is immediately above where the fuel line enters the carb but it is encased (hidden) so you can have the dealer pop the hole so that you can access this tiny adjustment screw yourself from now on. Just a tiny turn with a tiny screwdriver will have your hbz2610 rev like a champ. Both of mine bogged down after one month. Took the dealer 30 seconds to gain me access to the mixture adjustment screw. Occasionally need to readjust but a year later both still run great. Use 93 octane or that expensive ethanol-free stuff that comes in quart cans along with your two cycle oil mix. And don't forget the carbon buildup at your exhaust.
Posted on Jul 14, 2012
  • 6468 Answers
SOURCE: testing a coil from a vac attack II blower
remove the small wires from it and spin the engine over if still no spark the coil is bad
Posted on Aug 21, 2012
8500 redmax kill switch issue
They go bad all the time easily replaced
Oct 01, 2016 | Redmax Garden
Nospark to sparkplug
bad plug or bad coil
Aug 12, 2014 | Redmax Garden
How do I check if coil is no good
Ck for spark first then ck kill switch unplug wires..
Apr 05, 2014 | Redmax Ebz5100 Back Pack Power Blower...
How do you adjust the carburetor on th redmax HBZ2601
take it apart and clean it and put kit in it, make sure to put new screen in from kit, usually a kit and filter will take care of problem, I would change fuel filter first and fresh gas, then go from there. see a lot of problems with fuel now a days !
May 22, 2013 | Redmax Garden
Wy is my leaf blower not running at ful power, starts like it should
Check the spark arrestor in the muffler outlet ( if fitted ) is not blocked with carbon, also check the exhaust port itself is not blocked with carbon.
Feb 02, 2013 | Redmax Garden
If there is no compression can this be fixed
thinking is not a fact. pull plug wire off, pull starter rope. do you have pulses of resistance? Yes, =compression good enough. No, = expensive repairs(new head and/or piston)
Oct 27, 2012 | Redmax Ebz5100 Back Pack Power Blower...
Redmax ebz5100 blower stumbles/misfires periodically until engine is hot?
What happens if you play with the choke ? does it clear up or change, If it does then it's a fuel problem example : fuel filter, fuel line cracked,dirt in carb. If the choke does'nt make a difference then , try a new spark plug Good Luck, Let me know how you come out 2StrokeJim
Nov 27, 2011 | Redmax Ebz5100 Back Pack Power Blower...
Garden Logo
91 people viewed this question
Top Redmax Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Redmax Garden Expert? Answer questions, earn points and help others
