Question about Bosch Refrigerators
My bosch fride freezer exxcel the red light stays on what does this mean just put it on
  • 833 Answers
SOURCE: Dodgy fridge light
Generally, these doors drop from excessive weight, a warn part or loose fittings. Unload the door and investigate. You may also want to check that the unit is levelled...the box may be warping/sagging...although this is unlikely.
Posted on Dec 24, 2007
heavyt15
  • 91 Answers
SOURCE: bosch clasixx f/freezer fridge fime freezer playing up!
New defrost timer...
Posted on Aug 18, 2009
miket756
  • 2702 Answers
SOURCE: hi can you tell me what the red explanation mark
it has a problem and its telling you this,,,most likely its to warm inside of it this could be the thermostat playing up
Posted on Jul 04, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch exxcel fridge freezer - freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 20, 2010
SOURCE: Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Posted on May 23, 2011
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
Bosch exxel fridge freezer should the light go dim when the door is shut and not off completely
the light should go OFF when the door is shut.(that is if ive read your question correctly).
Dec 18, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
There is a buildup of ice behind the lower section of the plastic back panel which eventually prevents the door from closing.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Hi can you tell me what the red explanation mark on my bosch exxcel frost free version fridge means please. mike
Jul 04, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Left freezer open for night
You'll need to turn the unit off and leave both doors open for 48 hrs for it to defrost then try it again. cheers
May 17, 2009 | Bosch KGU34641 Bottom Freezer Refrigerator
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Dodgy fridge light
Dec 24, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Refrigerators Logo
32 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
