Question about Redmax Garden
How do I know if spark plug is getting fire, wont start
Older redmax leaf blower wo
    Top Expert:
  • 8,204 Answers
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
How do I check if coil is no good
Ck for spark first then ck kill switch unplug wires..
Apr 05, 2014 | Redmax Ebz5100 Back Pack Power Blower...
Wy is my leaf blower not running at ful power, starts like it should
Check the spark arrestor in the muffler outlet ( if fitted ) is not blocked with carbon, also check the exhaust port itself is not blocked with carbon.
Feb 02, 2013 | Redmax Garden
2pwes-0254by craftsman leaf blower wont start
check and see if spark plug is good,,,if so my be timing has jumped
Jan 04, 2013 | Craftsman Garden
If there is no compression can this be fixed
thinking is not a fact. pull plug wire off, pull starter rope. do you have pulses of resistance? Yes, =compression good enough. No, = expensive repairs(new head and/or piston)
Oct 27, 2012 | Redmax Ebz5100 Back Pack Power Blower...
Redmax ebz5100 blower stumbles/misfires periodically until engine is hot?
What happens if you play with the choke ? does it clear up or change, If it does then it's a fuel problem example : fuel filter, fuel line cracked,dirt in carb. If the choke does'nt make a difference then , try a new spark plug Good Luck, Let me know how you come out 2StrokeJim
Nov 27, 2011 | Redmax Ebz5100 Back Pack Power Blower...
I have an echo pb400e backpack blower. it wont start. getting fire but wont crank.
is your spark plug getting wet from fuel? try take air snorkel off carb and give it a shot of carb cleaner if it fires you have a fuel problem if it doesent fire , and plug is wet pull plug and rollover and get excess fuel out of cylinder, and try carb cleaner again, if no luck check compression, then if good go to flywheel and see if loose
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Redmax blower older model does not start, tried a few drops of gas in spark plug port and it started. but stalls after fuel in burned off, any help would be appreciated, djk913
Carb. problems sounds mostly like the carb needs to be thoroughly cleaned out, drop fuel bowl and hit openings with a tiny steel wire and carb cleaner also check the diaphram, sounds like its cracked/dried up.
Aug 02, 2010 | Homelite 'Yard Broom' Leaf Blower
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
HB-180 Leaf blower won't start
if its flooded then it surly wont fire,not a 2-stroke. are you over priming or is there a malfunction. remove plug,put plug not a tester in the end of lead,ground, and pull. spark should be purple and consistent. if red/yellow/intermitent. change he plug. if the engine is only flodding on its own then the needle and seat could be stuck open in the carb, gas tank vent in fuel cap plugged and building tank pressure, or fuel mixed too rich. let me know what you find
Sep 02, 2009 | Homelite Consumer Products MightyLite...
Garden Logo
77 people viewed this question
Top Redmax Garden Experts
Dennis Key
Dennis Key
john h
Are you a Redmax Garden Expert? Answer questions, earn points and help others
