Question about Lands Phones
One of my L7 handsets won't connect to the base. Have tried reregistering it and it still can't connect.
SOURCE: Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
otacon
  • 1944 Answers
SOURCE: Can not get the second handset to register to the base
After you got the no connection message after trying to register the second handset...did you try to register it again?
Posted on Jan 01, 2008
  • 3 Answers
SOURCE: Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Posted on Oct 02, 2008
  • 5 Answers
SOURCE: my phone keeps saying unable to connect
is your phone about a year old? It may be the battery. The vtech phones have weak batteries that clunk out after about a year and you'll get dropped calls, looking for base etc... The phone still appears to be working and the battery indicator tells you it's charged, but the battery is too weak to keep the wireless connection going.
Had the same problem and replaced the battery. budgetbatteries.com had the cheapest ones. But it's a knockoff, so I don't know how long it will last. So far it's been 3 months and the problems are gone. I would try that first and see how it goes. I paid about $15 including shipping. If you buy it from vtech it's at least double...
Posted on Jan 31, 2009
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
Phone is not taking calls from the base unit
It is not receiving phone calls or the intercom to the handset does not work? Try reregistering the handset. You must be at the base to do this.
Jan 27, 2015 | EnGenius DURAFON1X DuraFon 1X System Phone
Handset on base not working
Just wondering if you have tried to use one of the other handsets from the base.
My friends phone has done this twice in the past couple months. For some reason it just stops working. What I did to solve the issue was to just unplug the base for a minute or two and then plug it back in.
That seems to solve his particular issue for a little while at least, but whatever the issue is it seems very intermittent.
Jan 20, 2014 | Uniden D16804 D1680-4 w/ Range Extender...
I have extra handsets from a TRU9480 phone and
have it checked by ur near by customer service and ask them to connect
Aug 30, 2009 | Uniden TRU9496 Corded / Cordless Phone
No dialtone on handsets, 3 beeps sound
Deregistered 4 handsets, on suggestion from FixYa, by pressing hangup & # sign.
Then reregistered to base.
May 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How do I reregister a handset phone to the base phone? I changed the battery and now it won't get a dial tone.
Hold at the same time on the base the button above the red light and the # on the phone for a few sec. This will reregister the phone.
Apr 13, 2009 | Uniden Lands Phones
Cannot reregister phones to the base.
If your base is a VT2651:
1) take phone off of the base's cradle.
2) enter **335782 on the keypad
3) phone beeps
4) remove all batteries from handsets.
5) reinstall battery in 1st handset, and enter the code number for the base unit (sticker on bottom of base). First handset will be set to phone 1
6) repeat step 5 for all other handsets.
If your base is a VT2656, there is no keypad on the base. I don't know the trick to reregister the handsets. I wish I did, since that is the problem I am having.
Nov 22, 2008 | Vtech VT2600 Additional Handsetfor...
We have a Philips CD445 three handset phone. Unfortunately one of the kids have managed to UNREGISTER one handset. I have tried several times to reregister it but it does not see the base. Any ideas?
Make sure no phone is on the base. Bring unregistered phone to the base. Find the handset locater button. Press menu > advanced set > registration > base 1. When it requests a pin enter your pin 0000 BUT DO NOT HIT MENU YET. Hold the handset locator button ON THE BASE for 5 sec. then press MENU on the phone. It should register.
Sep 12, 2008 | Philips Lands Phones
Cordless GE 26928GE2-B
there should be some problem with the connection antenna
Sep 02, 2008 | Uniden Cordless Phone
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Jan 04, 2008 | EnGenius DURAFON1X DuraFon 1X System Phone
How to REregister handsets
You can unregister your phone without being in the cradle, but to re-register them, just put them back in the cradle.  After being unregistered, they will automatically re-register once they are put back in the cradle of the main base.  Try setting them back in the base cradle to re-register, and hopefully that will work for you.
Dec 01, 2007 | Uniden TRU9480 Cordless Telephone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
