Question about Car Audio & Video
I got a c d a ove on demo how do get back thanks
The ac unit was ,oved from one window to the other and it stoped working when we first pluged the unit into the wall started flashing i
It is possible that when unit was moved it was not kept fairly level and oil run out of base of compressor. Give it a few hours for oil to run back into compressor and then try it. Thank you.
Jun 20, 2011 | Heating & Cooling
Turned off demo mode but it turns back on on its own
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press left or right button to highlight the SET UP menu.
3. Press up or down button to highlight DEMO.
4. Press left or right button to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER.
I hope this helps. Thanks for using fixya.
Jan 20, 2010 | Toshiba 36A43 36" TV
How to switch off the demo on a JVC car radio
press and hold the select button and and when it says demo turn the volume knob until it says off then press select
Jan 02, 2010 | JVC Car Audio & Video
HI,I INSTALLED MY DEH-6500 PIONEER RADIO,CAME ON DEMO MODE,PUT CD IN VOLUME WORKS BUT CANT CHANGE SONG ON CD,TOOK CD OUT,BACK TO DEMO MODE WHERE I CANT DO ANYTHING,CAN YOU HELP GET ME OUT OF DEMO MODE...
Feature demo
The feature demo automatically starts when
power to this product is switched off while the
ignition switch is set to ACC or ON. Pressing 6
numbered button during feature demo operation
cancels the feature demo mode. Pressing 6
numbered button again to start the feature
mode. remember that if the feature demo continues
operating when the car engine is
switched off, it may drain battery power.
Notes
• You cannot cancel a demo mode when the
front panel is open.
• The red lead (ACC) of this product should be
connected to a terminal coupled with ignition
switch on/off operations. If this is not done,
the vehicle battery may be drained.
Apr 26, 2009 | Car Audio & Video
Demo Mode JVC KD-G333 head unit
Hi guys, I had this problem and i just found a solution.
I was on FM mode when i tried this:
Hold down "sel" until the display says "demo"
Turn the volume knob and the display will toggle between "demo on" and "demo off"
I went back to CD mode and the blasted demos no longer appear!
Jun 21, 2008 | Car Audio & Video
Panasonic SA-AK17 MASH stereo system
That demo mode thing is painfully annoying. With mine, I had to hold the 'display/demo' button in for about 1 second and then the words "NO DEMO" appeared. That fixed it.
Apr 24, 2008 | Audio Players & Recorders
Fixing Nokia 1110i phone off Demo mode
the only reason it says demo mode is because you dont have a sim card in it
Feb 09, 2008 | Nokia 1110i Cellular Phone
Can't put door back
This may help:
http://www.whirlpool.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196278.pdf?PIPELINE_SESSION_ID=62e5768ec0a8503448ca0e04446c0ca5
Oct 27, 2007 | Whirlpool RBS245PDS Electric Single Oven
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
