Question about Syntax LT20HVK 20 in. HD-Ready LCD Television
What display setting do i use for LT20HVK Multi-Media Display when hooking it up to an Xbox 360 with an HD AV cable?
How do u reset your xbox format to pop up on your tv?
If you're using the XBox 360 component/compositve AV cable, try the switch at the base of the cable to switch from HD to SD or vise versa. If that doesn't work, try MS's official reset instructions:
To reset your display settings, follow these steps:
  1. Make sure there's no disc in the disc tray.
  2. Turn off the console.
  3. Turn on the console.
  4. Note If you're using an Xbox 360 Wireless Controller, make sure only one wireless controller is connected to the console, and then turn off and restart the console by using the Guide button on that controller.
  5. As the console starts, press and hold Y while pulling the right trigger on the controller. The display settings are reset to the default settings, and then the console automatically restarts.
    Xbox 360 E or Xbox 360 S console: To reset display setting on these console models, you can also just turn off the console and then hold the power button on the front of the console down for about 10 seconds. (The lights will flash several times.)
Oct 20, 2014 | Microsoft Xbox 360 Console
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How to hook up Xbox 360 Component HD AV Cable to Sony KP-53hs10
I would be surprised if this model has component inputs from its age and if so it is not a HD set.
Oct 31, 2012 | Sony KP-53HS10 TV
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
My Xbox elite is just over a year old. I have no red rings. Problem is that all games played on the box are now in black & white. There is no colour on my tv screen. There is nothing wrong with the...
Check and recheck and triple check the av/hd cables. If you want to help isolate, try hooking up your xbox 360 to another tv and doesn't matter if it is hdtv or standard to test out. That method will give your answer quick to help isolate the problem. If you have hdtv make sure your adapter has the switch set for hdtv and not standard and then go in the xbox 360 dashboard system settings and see if it shows up for display. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Elite Console
I was having trouble with my component AV cable. I went to purchase a new cable, HDAV component cable and connected the xbox. I had an image for a short time and now do not. Please help!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
No display
Have you checked the AV cable? If you are not using a HDTV, on the AV cable, there should be a little switch (referring to the end that slots into the xbox), well, make sure that the switch (look really closely now) is pushed up to TV. However, if you ARE using a HDTV, ensure that the switch is on HDTV. If this doesn't work. Check to see whether the cables are correctly plugged into the TV. If using HDTV, the red and white should be plugged in next to each other, in the appropriate holes. And all the other colours (excluding yellow) should be plugged into their appropriate holes (for video). If not using HDTV, plug the yellow , red and white into their appropriate holes. Also, your HD settings may be incorrect, put the Xbox 360 into standard definition of a standard definition tv and chenge the settings into the appropriate settings for your television (go to system, settings, Display, HD settings etc. If none of these features work, contact microsoft or just buy a new cable. HOPE THIS HELPS!! From Mike
Sep 28, 2007 | Microsoft Xbox 360 Console
Syntax LT20HVK 20 in. HD-Ready LCD Television Logo
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
