Question about Electrolux Washing Machines
Electrolux washer dryer combo Model Mex731cfs4 not draining changed water pump still no draining
  • 244 Answers
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
Posted on Dec 12, 2007
  • 640 Answers
SOURCE: LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Posted on Dec 25, 2008
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
SOURCE: lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from for less than $50 + s&h.
Posted on Sep 06, 2009
  • 15935 Answers
SOURCE: kenmore stack washer/dryer combo. model #
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
Change dryer belt
Good Morning Friend,
I understand you are trying to change the dryer belt on your Frigidaire dryer, model# MEX731CFS4. Typically, this is not a do it yourself repair, as there are no step by step manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to change the dryer belt with ease. Hope this is helpful.
-Best Regards-
Jun 24, 2014 | Frigidaire Washing Machines
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
My Kenmore Washer Dryer Combo stacked unit Model # 417.92702200 will not drain it has noise and runs thropugh the cycle then spins like it should just will not drain out water after its done wash cycle....
looks to me that you have eather coins, yes,coins traped in the electric water pump mostly a quarter blocking the inlet of pump or a piece or clothing from the hose that comes from the bottom of the OUTER TUB to the PUMP. if not you may have a faulty pump.
good luck to you.
Feb 07, 2011 | Kenmore 22422 Top Load Washer
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
89 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
