Question about Samsung Televison & Video
I have a broken input on back of my vizio. The part # the cable goes into is samsung dtvs205ch201a if i find one of these can i take it off the circuit board and soider a new one on? Ted **********
2 Suggested Answers
SOURCE: The 'antenna in' cable hook up spins
I was a Tech for Vizio for 3 months I Have a couple board Brand new one of them in label Samung dtvs205ch201a 070705 IDT-LF
Let me know if that s what you looking for
my email is dessables@gmail.com
Posted on Mar 01, 2009
My vizio is blinking back and forth from the blue no signal screen to the actual hdmi input screen which is connected to a cable box. What is going on?
Have you tried a different HDMI input? (If available.) You may be able to test the cable box of PS4 using component cables to confirm that all but the HDMI is not working. You may try pushing or holding the HDMI cables to see if you can make the problem better or worse to identify a possible flakey HDMI socket.
Jan 03, 2015 | Vizio 26 Class Edge Lit Razor LED LCD HDTV...
What should I do in order to get the sound to turn back on my Vizio VX20L TV?
Have you tried the user manual? There may be a setting in the menu indicating whether to use internal speakers or some other device run through say, a cable or HDMI output, or turn off sound for those using a cable input to the TV from say, a cable box, but the sound goes to a separate sound system.
Also check that there is sound coming INTO the unit from your cable box if you have one and use RCA cables. If using HDMI input, there may be a menu item as well, to control whether to use input or not, as some people will have the cable box send the sound to a sound system instead of the TV.
Oct 26, 2014 | Vizio VX20L 20 in. LCD TV
Hdmi cables input 1,2,3,4 which input goes to the tuner, direct tv box, blue ray on vizio E550i-AO
The choice is entirely arbitrary. You may connect any accessory to any HDMI input. I recommend you connect the device you use most (probably your direct TV box) to HDMI 1, your second most frequently used device to HDMI 2, and so on, but it's really a question of your own preferences.
Mar 18, 2014 | Vizio E550i-A0
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
My vizio tv hdm cables quit working
Check and replace its main power regulator board.
Sep 26, 2012 | Vizio VF550M 55 in. LCD HDTV
No Signal form Samsung DVD R 155 to Vizio TV
tried to hooked up to other tv or other component input with in the tv and replacing cable wire just to ensure where the main cause of the problem.
Sep 02, 2012 | Samsung Televison & Video
Vizio e370vl 37" LCD TV powers off by itself. It comes on, displays Vizio logo white, then turns off and goes to yellow. We tried unplugging everything for 5mins. Tried changing inputs, no RGB cable c
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 25, 2017 | Vizio E370VL 37 in. LCD HDTV
I HAVE A VIZIO LCD TV AND WHEN WATCHING ANYTHING THROUGH THE hdmi INPUTS LIKE BLUERAYS THE SOUND GOES STATICY AFTER 30 MINS. AND TO RESET IT I CHANGE THE IMPUT CHANGES THEN BACK AND THEN ITS FIXED. WHAT...
This problem happen to all the HDMI inputs?Only one HDMI input,that one properally is shorted.Might even the HDMI cable is old,and worn out.U have about 6 HDMI inputs on ur tv,rent about 3 DVDs movies and watches test out all ur HDMI ports out.
Mar 25, 2010 | Vizio VW42LF 42 in. LCD HDTV
Feb 21, 2009 | Televison & Video
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
