Question about Electrolux Washing Machines
Electrolux MEX731 cfs4 not draining changed pump still no luck
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Sep 13, 2014 | Electrolux Washing Machines
How to acess the drain pump on an electrolux front load washer
Good Morning Friend,
I understand you want to know how to access the drain pump on your Electrolux washer, model# EIFLW55HIW. Typically, this is not a do it yourself access, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to access the drain pump with ease. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Where is the drain pump on a Electrolux front load washer
I understand that you want to know where the drain pump is located on your Electrolux washer, model# AWF 1435. In researching the model number you provided, I show that this was manufactured in France. I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you where the drain pump is located in your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux AWF 1435 Front Load Washer
Not draining burning smell electrolux front load
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 25, 2012 | Electrolux EIFLW55H Front-Load Washer with...
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
My electrolux frontload washer seems to be stuck on the "drain" cycle. It is making a loud buzzing noise and will not drain or perform any function.
Hi
Loud buzzing sound is coming from drain pump. It is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter.
Hope this helps... Please post back if you need more information.
Daniel
Feb 10, 2011 | Electrolux EW1000i Front Load Washer
Electrolux dishwasher error c8 What does this mean please??
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
May 19, 2010 | Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
