Question about Karcher Garden
I have a electric karcher from my deceased neighbor i think only one year old but cannot find the model number on it in order to get a maqnualand know the pressure
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Posted on May 30, 2009
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
SOURCE: karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to where you will be able to find pretty much anything for your preassure washer.
Posted on Jun 26, 2012
  • 4 Answers
SOURCE: I have a Karcher K5.55M The motor pulses and only 1/2 pressure
In the video link above, at 7 minutes,.. through to 7 minutes 8 seconds,.. the guy talks about a "minute crack in the cylinder head". He actually means to say "minute crack in the control head". This minute crack is the main reason for this common problem: the pulsating and some loss in pressure on a wide range of Karcher waterblasters.
I got a replacement control head from my local Karcher dealer for NZ$50 that fixed the problem,.. for now :-( The below picture has two red ovals around the cracks in the control head that are very hard to see. If Karcher made this control head from an aluminium casting, their product range would be a LOT better. eade87d9-b4d8-4625-bd50-c466405ff2e3.jpg
Posted on Oct 20, 2014
The Model # is 311-H and the Serial Number is D277127. It is an old gun that belonged to my Grandfather, who is deceased. Trying to find the year it was manufactured, to know how old it and the value. I...
The 311 was in production for 20 years with the A,B,C,D,E serial prefix from 1968 to 88 so from that your one is a 1980-81 approx age
Mar 16, 2015 | Optics
Karcher 1600 pressure washer will not get power. It was working then stopped getting power. It is not that old.
ok im a technician... cheak d power swtich. i think most of karcher power knob switch they got a error problem.
May 30, 2011 | Karcher K2.26 Electric Power Washer
This machine was purchased in October 2008. Has had minimum use because of water restrictions in Brisbane and since that has changed started using it more recently and now won't go. When turned on the...
this sounds like it could use a new capacitor. What the capacitor does is jump starts the motor and fan in order to run the machine. It is not a costly part to change and you should get the part at your local dealer/supplier as the K5.93 isn't that old of a model. There is a simple test that the technichian can do to make sure if its the capacitor.
If you give me the number on your machine silver plate I can get the exact part number for you.
Jan 23, 2011 | Karcher K 593 M Electric Pressure Washer
To me this problem sounds like there is something wrong with the pump.
I think its better to buy another Karcher machine and get the 12 month warranty. As with old pressure washers you could spend money on certain parts to fix the machine but a few weeks/months down the line a different part of the machine could break and then you end up having to buy a new machine anyway.
Also being 15 years old you would have to check to see if parts are still made for the machine. This is because once Karcher discontinues a machine parts for that machine are manufactured for 10 years from that discontinue date.
Jan 17, 2011 | Karcher Garden
Water is leaking from under the chrome piece inside my Karcher 3.68m pressure washer. Hose intake and outlet look good. Any sugeestions.
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Jun 08, 2010 | Karcher K3.68MR Factory Refurbished 1,800...
I have had 3 Karcher pressure washers all experience the same problem and so have two of my neighbors. Our area has very hard water and it causes problems with the washer not bringing up the pressure when...
If your water is that hard (and it appears it is) WD40 will NOT solve the problem. You should look into a water softener. However, chances are that a small, inexpensive model will not have the flow capacity required for a pressure washer. You'll likely need to look at a larger, whole-house model.
Use vinegar to through the machine's "soap" dispenser to break up the hard water deposits or a heavier solvent such as CLR which is available at most retail outlets.
Nov 04, 2009 | Karcher K2.26 Electric Power Washer
Problem with pressure washer line seems to be cracked the line that has the gun and puts the water out has a crack how do I get a new one?
Lowe's and Home Depot keep a supply of hoses. Take the old one with you, and match it up. Or, you can take your make and model number and order one on-line.
Regards, --W/D--
Jul 14, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
How to identify a bernina sewing machine
Older machines, the model number is found on the throat of the machine and sometimes stamped on the cover over the motor. You can also give me the serial number stamped on the machine and I can look it up for you. I am a certified Bernina/Brother dealer and technician.
Perhaps look at Ebay, you may get lucky before your eyes become crossed looking at the many many Bernina models out there.
Sep 19, 2007 | Bernina Artista 180
Garden Logo
121 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
