Question about Panasonic Lumix DMC-TZ3 Digital Camera
Lumix FX9 - LCD screen is very dim
Lumix FX9 - all of a sudden the LCD screen is very dim. Almost nothing can be seen indoor now. When outdoor under the sun, image can be seen barely. What's wrong?
5 Suggested Answers
mcomijohns
  • 477 Answers
SOURCE: Casio Exilim EX-Z60 - severe overexposure - entire image is white
Yes the place sold you a camera with a bad CCD. They should replace it for free.
Posted on Jun 02, 2008
  • 5 Answers
SOURCE: lcd
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Posted on Aug 09, 2008
Nittram
  • 34 Answers
SOURCE: vertical lines & white screen outdoors
Hello, the other two replies are good answers, but it could also be the shutter magnet causing interferance with the picture creating lots of tiny lines accross the picture and causing the picture to be grossly overexposed.
In Australia these cameras do not have a ccd recall issue and in our workshop we have not had to replace any CCD's on these particular cameras.
Lots of lenses though (as the shutter is not avalible seperate) with similar problems to as you have described.
Sorry for the bad news.
Posted on Nov 08, 2008
taosStuff
  • 7 Answers
SOURCE: blury images
Firstly, Yes, if you want to reset all settings to factory default you can do so on most every digital Camera and imaging device that is manufactured today.
there are no specific model details in your question, but generically, you should find in the 'Settings' or Set Up' menu, that 'resore factory default' or restore default settings' will be one of the final options on the list, generally found in the same menu where you will have first set the time and date etc when you 1st purchased this camera.
Now as for the low light - indoor - blur on images, This is almost certainly due to low light levels and the CCD sensor failing to keep up with the light levels between say the window and the room during the daytime or the electric light source and the person/object of your photo at night.
Do you use the Flash? are the results clearer (if harsher)?
Understanding that perhaps you don't want to use the flash, you should make sure your camera is as steady as possible, if you don't have a Tripod, then lay it on a table, or even nestle in a cushion is fine. Then press the shutter button as gently as possible, first halfway down until you hear the camera finish it's auto focusing process, then gently take the shot.
A couple of other tricks you may have success with (again depending on model) are either lowering the resolution of the images, Say for instance you have a 6 mega pixel camera, this is an image quality that way exceeds that which you need for taking family album snaps. you will have perfectly enjoyable and printable images at a resolution setting of 2-3 meg pixels, this will allow the camera's processor to manage far more swiftly, due to it being designed to - hopefully - cope with a far higher MP level.
Finally, i have resolved this shake and blur problem by setting automatic digital cameras to the 'speed' setting, - Usually a small image of a running man or couple - or if you have a 'scenes' based menu, choose the one used for fast moving objects, i.e, motor sport etc. I know this appears to go against all logic, but it seems the faster shutter speed eliminates some blur, whilst the shutter speed on Automatics is not fast enough to noticeably darken the image. presuming of course you have what you would consider 'sufficient' lighting.
OK, well that's about as clear as I can be without knowing the model of your camera, But good luck with it... it's generally just getting to know the highlights and pitfalls of small automatics that is the key to success and enjoyment with them, just use it at what it's best at and accept compromise with the less good aspects.
Posted on May 09, 2009
Can I use 4gb sdhc card on lumix fx-9
No. The DMC-FX9 works with SD cards, not with SDHC cards.
Nov 02, 2012 | Panasonic Lumix DMC-FX9 Digital Camera
Screen is black, backlighting gone, but camera still works. Is there a solution for fixing?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 26, 2011 | Panasonic Lumix DMC-FX9 Digital Camera
My LCD monitor on my Panasonic DMC-FX9 camera is very dim, so much so that I can take pictures. How do I fix this issue?
Most of the camera's have brightness/contrast settings for the display, see the manual for how to change these settings
Jun 17, 2010 | Panasonic Lumix DMC-FX9 Digital Camera
Broken screen on panasonic lumix dmc-fx9. Is it
It is not worth fixing it because it will cost you alot . The cost of repairing screen will be around $70-100.
Jan 27, 2010 | Panasonic Lumix DMC-FX9 Digital Camera
LCD Screen went black!!!
hi..
I had the same problem. The flex cable for backlight was broken. I take out the backlight LED module. There have one resister along with 4 LED. I soldered two wires (AWG 30) onto two sides of resistor. Just follow the trace of flex cable and then solder the wires to the pins of connector directly. Although there have 4 wire on the backlight cable, it only need two to work. In order to avoid any finger print and dust fall on to the LCD, it would better wear a hat and plastic glove during this operation.
thank u
rate me!!
Jul 26, 2009 | Panasonic Lumix DMC-FX9 Digital Camera
Color Display on Panasonic Toughbook CF-28 is dull
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | Panasonic Toughbook 28 Notebook
Panasonic lumix dmc-tz3
The TZ series is not known for good indoor pictures. T Z is short fot Travel Zoom. The is great for outdoor pictures and long distance shots.
Indoors, be sure you use flash and your subject is within 8 feet so flash light can reach them. Let the camera select the proper settings using the Intelligent ISO setting.. Or set it to Night slow shutter speed) while holding the camera, and subject very still for 3 seconds after shutter press, and with Image Stabilization on.
Also, don't forget if you are viewing the pics on your big screen PC, then the pics will always look worse than they will either on your Camera screen professionally printed pix fo 5x7, which will likely be fine to acceptable. If you get up to 9x10 printed sizes, then you will likely see what you would see on a large PC screen....not very good.
There is a chance you have a bad camera. If it is under warranty, take it to a panasonic repair center locally. I am afraid if you send it off to a depot, they may charge you while declaring nothing is wrong with it.
Nov 19, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Not focusing
the focus motor is either stuck or broken, i would check this first
Mar 29, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
The camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 31, 2005 | Panasonic Lumix DMC-FX9 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
140 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
