Question about Dimplex DF2608 26 Inch Electric Firebox
My dimplex df 2608 suddenly one day wont turn on ? Can you help?
Dimplex cheriton fire model CHT20LE wont turn on
Check the fuse isn't blown in the plug. If it is not, then you would unfortunately need to open up the fire and check the internal wiring and connections, check the switches with a multimeter to make sure they are working. There really isn't much inside these units to go wrong! So any fault should be rather easy to find
Aug 02, 2013 | Dimplex Heating & Cooling
Fire wont mist ad keeps turning its self off 3rd time lucky at posting this as not a car or truck and it keeps coming up under cars or trucks
You can call Dimplex directly for Tech Support:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex Compact Electric Flame Stove...
The LCD (24 hour timer) is blank so the heater wont work
There is nothing you can do, turn on your oven if electric, or if gas open a window 4 inches and dont sleep with a gas burner running.
Oct 25, 2012 | Dimplex OFC2000TI Heater
How can I hook up VHS or DVD to my Audiovox FPE 2608? Thank you for you help, LaCrecia
via a converter that will take your normal rca or component plugs into hdmi
Mar 24, 2011 | Audiovox FPE-2608 26 in. LCD TV
Dimplex Electric Heater Model Number DF 3003 fan motor not working. How do I access the fan motor to repair or replace it?
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Mar 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Vivitar DF-283-CAN flash suddenly won't go off. I hear it power up and the ready and ettl lights go on but the ok light doesn't light up and the test button wont work either.I tried replacing the batteries...
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Jan 01, 2010 | Vivitar DF-200 Flash
Help
Dimplex has a number for you to call: 1-800-668-6663 ext# 358 TELL THEM YOUR PROBLEM AND THEY WILL PUT YOU IN THE RIGHT DEPARTMENT. I had problems with the main switch and they sent me a new one.
Nov 05, 2008 | Dimplex Compact Electric Flame Stove...
Dimplex night storer, how does it work?
Are you setting the input to maximum and the boost to late? You do not say what size the heater is in either kilowatts or kilowatt hours eg 2kW or 18kWh. These heaters will tend run out of stored heat in the evening especially in colder weather.
Jun 08, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex DF2608 26 Inch Electric Firebox Logo
41 people viewed this question
Top Dimplex Kitchen Ranges Experts
Richard Lane
Gene Haynes
Are you a Dimplex Kitchen Range Expert? Answer questions, earn points and help others
