Question about Watches
Sonic watch b10 instructions - Watches
Why the Time stops after am hour when i use the buttons on the side of the watch
Watch Instructions - WatchStation Official Site: Watches
www.watchstation.com/instructions/
Chic, Stylish & Vintage Fashion from WatchStation. Shop Watches, Wallets, Bags, Belts, Sunglasses, Jewelry & More for Men and Women. Incredible looks at ...
Watch Care & Instructions - Fossil
https://www.fossil.com/us/en/...care/watch-instructions.html
Fossil GroupStainless Steel Watches ยท Vintage Boyfriend Watches ..... Select your language to download a PDF version of our watch instruction manual. If you do not see ...
Timepieces(Watches) - Manuals - CASIO
Jan 01, 2016 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
I have a sonic terramax watch and everything work except the arms for time do not move. Anyone have an answer for me
This watch have two batteries. When you open tha back you'll see a big battery mounted on the printed circuit board (PCB). If you unscrew the screws from PCB and take it out, you'll find under it the mechanism with the battery from the analog watch. Replace that battery and "Have a good time"... :-)
Aug 10, 2012 | Watches
I need instructions to operate a Ladies Rotary Chronograph Dolphin Standard Watch
Rotary do not seem to list instructions for individual watches but do offer general instructions.
To see these go to http://www.rotarywatches.com/en/service/rotary-watch-care#instructions .
\i hope his helps.
Jul 27, 2010 | Bulova Watch
Is a manual available for a Sonic B16 Renegade watch? What is the battery type and how to replace battery?
Remove the back, take out the two screws on either side of the CR 2016 coin battery. Replace.
Jul 05, 2010 | Gametime Seattle Sonics Coach Series Watch
In am trying to find users manual for a Connisseurs Sonic Jewelry Cleaner
You can visit manufacturers site here:
www.connoisseurs.com
If this is not helpfull, you can phone them on:800.851.5333 and ask for users manual (instructions) to be posted or emailed to you.
Do not forget to rate, please.
Jan 13, 2009 | Watches
Hands only move back and forth
The battery you put in may also be defective to start with. You need to have a proper watch battery tester to know if the battery is actually good.
As for cleaning a watch the watch maker will take all the tiny mechanical pieces apart, put them in to a very fine screen basket, and submerge the pieces in to the cleaning solution inside of an ultra sonic cleaning machine. Once cleaned he will maliciously re-assemble all the pieces in back in to the casing structure and lubricate with the very fine 000 viscosity oil used for watches. Then he will perform all the necessary mechanical adjustments.
Personally, if not properly trained and not having the proper tools and jigs I do not think you would be able do this type of work without ruining the watch...
Feb 10, 2018 | Bulova Quartz Two Tone Steel Watch for Men
Instruction manual required for diesel watch DZ 7033
i have found the solution by visiting this site
http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
All diesel watches manual instructions or (guide)
jamil soomro
toronto
Mar 02, 2008 | Diesel Audio Diesel Watch
Raymond weil tango watch 4795/1
i'm not sure the references of your watch are correct, but if it is a Quarz movement such as the RAYMOND WEIL Tango Ladies Watch or RAYMOND WEIL Tango Mens Watch you will find the instruction manual about setting and operating the alarm on the Instructions for use page of the official website : Watch Instructions page ( direct link to Watch instructions in pdf ).
Hope this helps :) david
Jan 14, 2008 | Raymond Weil W1
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
