Question about Cell Phones
My phone has an echo or repeats my voice on calls
    Top Expert:
  • Cell Phones Master
  • 4,740 Answers
Posted on Dec 01, 2016
Getting an echo of my own voice during a call
Hi, Irene Garla!
When did you start experiencing this type of issue from your cordless phone? Usually you get echoes of your own voice when your base phone is on speaker mode. Either you get an echo or a feedback from the speakers from both units when you're on a call.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Nov 05, 2013 | Uniden Cordless Phone
Www uniden com au
Hi, Irene Garla!
Mongkey
(for Windows only)
Nov 05, 2013 | Vtech 5.8 Ghz Handset Cordless Phone...
I hear echo
Are you or the other person using the speaker phone function? Does this happen during conference (3 way) calling? If you're using the speaker phone function, especially during a conference call, you're likely to hear an echo. I've had this very same issue with a different phone and the only solution I found was not to use speaker phone.
Good Luck!
Jan 05, 2013 | HTC EVO 4G Smartphone
I can hear my own voice echoing during calls to other phones. The worst is when I talk to my wife who also has the same phone Samsung Instinct with Sprint Any way to fix this? The echo will at times last...
It's a common problem with the network. There is nothing you can do but call back the person. Anyone tells you different they are pulling yor leg, my wife and I have Iphones for 3 years now, and sometimes it will happen for a few weeks and then stop. Some phones do it more than others, you can try an upgraded sim card, but if you have everything new I doubt it will help, sorry.
May 17, 2010 | Samsung Instinct Cell Phone
Our new 6.0 Caller ID phones have an echo. Can you suggest a remedy? John Chalk johnchalk@hotmail.com
as per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know"
Feb 11, 2010 | Panasonic (KX-TG1032S) Phone
Echo on my end when someone calls! Please help! Thanks!
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
T7316 Dropped calls and voice echo
How are your lines coming in to your phone system?
Generally you get an echo on VoIP lines not set up correctly.
T7316 should not give echo, as it is a digital phone.
May 29, 2009 | Lands Phones
Echo on line and dropped calls with A88
I dont know on this exact phone but here is for a similar see if this will work for you.
First make sure the User profile you activated has the Ring type set to Repeat so the ringtone works continually
rather than ringing once & stopping! Go to Main menu => Settings => User profiles => [Select a profile] => Customize => Ring type = Repeat
Save the settings & as you back out of the menus make sure the profile is Activated, as it should have a large green checkmark next to it.
If this setting is already set to the Repeat option, and your ringtone does repeat, but just doesn't seem to ring enough times, read below.
Also see if your phone has the below settings somewhere in your phone's menu system. As firmware are different so can the menu system
be different. If you cannot follow the exact path to find the option below, look in other areas of your phone's settings for the settings, but
know that your phone just may not have the same settings anywhere.
Call History => General Settings => Sim1 Call Settings => Call Divert => Divert if no Answer => Activate => To Voice Mail =>
Now choose the time length you require, 5, 10 15, 20, 25 or 30 seconds.
Mar 22, 2009 | Dual Electronics CECT P168 Cellular Phone
My Philips SE 450 sounds awful. I hear my own voice in my phone as I talk. It is like an echo.
you may have to enable a feature called voice enhancing on your voice, the echo is sometimes caused by feedback from various sources. it should appear as a VE symbol when you have it turned on, this helped me greatly when I was going through the same prob, it also makes the phone reception sound better on both ends. you may have to call the phone company to check to see if they installed the lines right in the first place. Also if your phone has the ability to change channels you can keep switching channels until you find one that sounds better to you.
Nov 13, 2008 | Lands Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
