Question about Vtech Lands Phones
What does error code 101 and 103 mean on vtech phone
After receiving an incoming call, approx 5 minutes after I disconnect, the phone will ring with the number display of 101 or 103 and there is no one there and then it just keeps ringing and ringing and calling back e point I have to disconnect the phone for a few hours to reset...HELP
CORDLESSGURU
  • 106 Answers
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
Your caller id log is full, you can fix your phone by pressing the Calls button, then the delete button over and over until it is empty. This will fix your problem without deleting all your programming.
Posted on Feb 10, 2008
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
  • 49 Answers
SOURCE: VTech model TM3111-2 the time
Assuming you are using T-Mobile@Home for your telephone service you should then;
type into your web browser address bar - 192.168.0.1
On the 'Setup' Tab with the sub category of basic setup look down towards the bottom of the screen for 'time setting.'
Click in the arrow for the drop down box and select your appropriate time zone.
Click on 'Save Settings' and you should be good after that.
Posted on Jan 07, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
consultel1
  • 860 Answers
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Jan 12, 2010
My ringer is muted when i have incoming calls so cannot hear the phone ringing vtech dect 6.0
Since you declined to specify the model of your VTech phone, enter the model number into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to get a copy of the manual.
Jul 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do i turn the ringer down on the handset, we have 5 handsets in the house and they all ring upon incoming calls and it's too loud.
Since you declined to specify the model of your VTech DECT 6.0 phone, enter the model number into the search box at
to download the manual.
Apr 14, 2011 | Vtech DECT 6.0 Digital Cordless Phone
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Ringer rings continously without pausing when receiving an incoming call
My phone no longer does the rhythmic vibration for incoming calls. I used to have it set up to vibration type 2 (where it vibrates in a certain pattern). However, as of last night, any incoming call just vibrates regularly instead of in a pattern. I checked to make sure that the setting was not changed, and everything looked ok. Is there a registry edit I can do to change this? I would rather not hard reset my phone, but I will have to do that if there's no other way. Thanks
Aug 11, 2010 | Vtech CS6219 Cordless Phone
Vtech phone does not ring on incoming calls
hi I have new vtech cs6859 just I buoth yestarday the doase not ringing
Jul 23, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
Only one ring with incoming calls from my Vtech and line is noisy. How do I solve this
Sounds more like a phone line problem than trouble with your phone. I suspect you have water in the line or some other problem that is causing trouble when the high ring voltage appears. Try disconnecting all phones and connect a plain old basic phone to one of your jacks. Better yet, if your house has a network interface jack on the outside, connect the phone there. Call your number and see if you still have the same trouble on the line. If so, call your phone company as the problem is in their wiring. If not, reconnect each phone in your house to see when the problem returns. Then you'll know which one is responsible.
Apr 14, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
Lands Phones Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
