Question about Ovens
My upright 900cm Arda oven doesn't work elements not heating up
Model RVU90FWB
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 750 Answers
    SOURCE: Oven heating element
    Hello rvready
    You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
    I am not able to find this part either.
    Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
    Today's appliances save you the arm and the leg that such an old oven is costing you.
    You have no idea how it is sucking your money out of your pocket!
    It is unfortunate, that no one told you about this years ago!
    You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
    Shop for a new one and see your bills go down.
    my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
    That means I threw away $7000. in 6 years with my old world attitude.
    Yes I am old fashion and always fix it!
    But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
    Hope I saved you some bucks with my real life stories!
    Don't tell your wife!!!
    Posted on Oct 17, 2008
    • 3463 Answers
    SOURCE: smeg oven
    Sounds like you need a new oven element fitting.
    Posted on Dec 08, 2008
    SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
    I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
    318022002 is the part number for the relay board with transformer
    318022001 is the part number for the relay board without transformer
    Yes the one without the transformer is more expensive for some reason.
    The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
    To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
    NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
    Posted on May 13, 2009
    Whirlpool double electric oven model D245. Buttons beep when pressed, oven lights up when door opened. Cost to repair control board?
    that isn't a good model number,how old is this oven?if it's over 15 years you can't get parts for it most likely,when you find the model number off of the oven go here and see if you can still get parts for it.
    Sep 27, 2017 | Whirlpool Ovens
    Does anyone know what the part numbers are for the baking elements in the oven upper and lower, model is an LG LST5651sw
    Here is the link to LG appliances LG RANGES OVENS Support
    I entered the number you provided and it couldn't find a match; you might want to re-check the number, or look at a model close to yours.
    Mar 24, 2015 | LG Ovens
    Unable to find model number for electric oven
    Hello, Smlmyers -
    Look at the image for the location of the sticker with the oven model on this web page:
    Scroll down the page. The image is near the bottom.
    Best wishes from a volunteer answerer in the USA.
    Jan 18, 2018 | Ovens
    Fault code E4 F3
    The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
    You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is .
    I hope this helps.
    Sep 07, 2012 | Whirlpool Ovens
    Kenmore serial number vf44745959
    hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. !!
    Feb 20, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
    You can order the paper manual from Sears by calling 1-800-252-1698. They will need the entire model number though. Here is info on where to find the model number:!retrieve.pd?modelNumber=70402&pathTaken=partSearch
    You can download the manual here:
    Again, you will need the entire model number. It should be located under the lid or on the back of the unit. It will start with three numbers followed by a dot, then many more numbers, such as:
    If you have any further questions or problem locating model number, let me know and I can help further.
    Aug 02, 2010 | Ovens
    What model will relace my Stove Drop in Model
    I will find out and contact you on Wednesday for this question. Ella
    Aug 19, 2009 | Ovens
    Need exact model No for JKP85 Double Oven
    unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
    Nov 25, 2007 | GE JKP85 Electric Double Oven
    Ovens Logo
    82 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    Are you an Oven Expert? Answer questions, earn points and help others
