Question about Porter Cable Air Tools & Compressors
Why does the compressor come on when in off possition
60 gal.220 porter cable air compressor
5 Suggested Answers
  • 574 Answers
SOURCE: I received no manual for my 60 gal. Porter Cabel
being that its 220 on the compressor Is where I assume you are wanting to know where the wires go? There should be a terminal strip or box that has a terminal strip by each terminal there should be L1 L2 and either ground or neutral. The two hot wires one each go to the Line terminals and the ground or neutral to marked terminal.
Posted on Jan 10, 2010
  • 36 Answers
SOURCE: My Porter cable CFFN250b-2 pancake 6 gal 135 PSI
head gaskit blown
Posted on Jul 30, 2010
SOURCE: my porter cable c2002 150 psi gal compressor the
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Posted on Dec 20, 2010
mxc2
  • 146 Answers
SOURCE: how to remove muffler intake from Porter Cable CPF6020-1 air compressor
To remove the air filter intake muffle you will need to remove the 4 screws that hold the head on to the pump.
There is a O-ring under the head you will want to put a little vasoline on before you reassemble the head back to the pump.
The new muffler kit should be the KK-4981
Posted on Oct 11, 2012
Can i use existing drain plug for porter-cable pancake air compressor?
Yes use pipe thread seal. The center is turned to open and close no need to remove plug. If is frozen replace.
Feb 16, 2018 | Porter Cable C2002 150 Psi 6 Gal...
How to test electric switch on porter cable air compressor
What you need is something called a volt-ohm meter.
Obtain one and use it to test your switch and wiring.
May 26, 2014 | Porter Cable C2002 150 Psi 6 Gal...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
I received no manual for my 60 gal. Porter Cabel air compressor (model #VT627504AJ) and I need to know the spec. for wiring.
Jan 09, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter-cable compressor stops and restarts at about 60psi
You prolly have a leaky gasket in the main valve. Air is leaking and causeing it not to go about 60psi, you probably have it set to reach a high PSI but since the leak is not allowing it reach above 60 it keeps cycling trying to get above it
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Air Tools & Compressors Logo
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
