Question about Toyota Sewing Machines
How do I adjust the tension on a Toyota Model 6600 serger?
Threads are all to loose.
  • Toyota Master
  • 11,748 Answers
Perhaps the manual will be helpful:
Toyota 6600 Instruction Manual
http://www.aisin.at/assets/manuals/SL1SL1TSL1T-XSL1A.pdf
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiD8qWcttPQAhWCw1QKHax5CagQFgg3MAQ&url=https%3A%2F%2Fconreicrismor.files.wordpress.com%2F2015%2F11%2Ftoyota-overlock-model-6600-manual.pdf&usg=AFQjCNFtz0ger6dBipYmZbiLjYrsDWhSAw&cad=rja
Be sure to raise the presser foot during the threading process. Also, make sure to give each thread an extra little tug when threading the tension disk.
Posted on Dec 01, 2016
Toyota overlocker sl3000 ; 3rd thread keeps snapping. How do I stop this ?
Third thread--is that the upper looper? Remove all the threads from the machine. Clip them below the thread tree, RAISE the presser foot, and then pull all 4 threads down through the needle. (Never Pull Up!!)
ALWAYS RAISE the presser foot.
Rethread beginning with the Upper Looper, then Lower Looper, then the needles. Be sure to ALWAYS thread in this order!! (On most newer machines, when threading the Lower Looper, always finish with the Lower Looper "draped" over the top of the Upper Looper.)
If a thread breaks, remove the threads and start over from the beginning as trying to fish a thread through the existing threads very SELDOM works.
Verify each thread path is correct.
When threading each thread and to insure the threads are seated in the tensioners, give each thread an extra little tug when going through the tension disk.
Be sure to oil your machine frequently to keep it operating smoothly!
Make It Handmade Threading Your Serger or Overlocker
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
May 03, 2017 | Toyota Sewing Machines
How to adjust the tension of the serger machine
It helps a lot to use 4 different colors so it is easier to tell which thread tension needs adjustment.
Sergers have tension dials for every thread. Start out with the dials set at the midway point between high & low numbers (this is the factory standard, however, the settings can change with machine use and wear). Be sure to RAISE the presser foot while thread every thread--this allows the tension disks to open. It also helps to grab the thread with one hand below the thread tree and, with the other hand, grab the thread below the tension disk and give it a little tug to insure the thread is seated all the way in the tension disk. Check to make sure every thread is threaded in the proper order (consult the owner's manual) and that every thread follows the correct path.
Test. Tweak the thread tensions. Higher number usually tightens a loose tension, lower number loosens. The correct tension is when the looper threads meet at the very edge of the fabric without causing fabric pucker; needle threads should be smooth with no loops or pulliing.
Mar 10, 2016 | Sewing Machines
Serger Adjustment
Whichever thread that is causing the loops may not be seated properly in the tension disk. Remove all the threads. Be sure to RAISE the presser foot BEFORE threading any of the threads. Re-thread from the beginning. With each thread, hold the thread above the tension guides and give each a tug below the tension disk to make sure the threads pop into place. Set all the tension disks at the midpoint between the high & low numbers. Test sew.
If it appears the threads are pulling through loosely, could be the tension disk(s) are not functioning properly. Can try cleaning them:
Remove the threads and loosen all the tension disks to the loosest possible setting. Raise the presser foot. Dampen a length of pearl cotton thread with rubbing alcohol and gently pull it down a couple of times between each tension disk.
Tighten the tension disks. Rethread and test your machine. If the tension is still too loose, may need service.
As for adjusting timing, search the internet for YouTube videos or web sites that show how to do that.
Dec 31, 2015 | Sewing Machines
Pushing material away, but still overlocking
It is difficult to tell what exactly is happening with your serger.
First thing--make sure you RAISE the presser foot BEFORE you thread any of the threads. This releases the tension disks so the threads will seat properly. You may need to remove all the threads and rethread from the beginning, making sure you thread each in the proper order. Start out with the thread tensions set at the ideal setting--usually the halfway point between the high & low numbers. From there, you will adjust them to even up the thread tensions.
Are you actually trimming off some of the fabric as it is stitching? If so, you might try increasing the cutting width (moves the cutting edge further toward the right) so that there is more fabric caught within the looper threads. It also appears that the looper tensions may be too loose. Try tightening the upper and lower looper tensions so less of the thread loops don't fall off the fabric's raw edge.
Make It Handmade Understanding Your Serger Features
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Meet Serge Beginners Guide To Using an Overlocker Serger
Using Serger Learn to Use Your Serger to the Max
Bernina 700D Serger 8 Cutting Width Knife Adjustments
Dec 30, 2015 | Sewing Machines
How do I set the tension on my JANOME 3434D serger?
Begin by setting all 4 dials on "3" which is the default setting on this model (often "5" on other machines). If a beginner, it would be best to thread the machine with four different colour threads according to the colours indicated on the tension dials (yellow, red, blue &green) so that it is easier to see how each thread responds as you adjust the dials. The two lower dials are for the loopers & must be adjusted until the upper & lower loops meet on the cut edge of the fabric - if below the edge: tighten the left dial & loosen the right dial (& visa-versa) just a fraction at a time. The two upper tension dials are for the needles: if too loose, loops form underneath the fabric below each needle, & if too tight the lower threads will show through to the upper side of your fabric where it is pierced by the needle. Good luck!
Jan 18, 2015 | Janome Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
Free Manual for Toyota Serger 6600
just click on this , or simply copy and paste it in address bar , press enter , http://www.aisin.at/assets/manuals/SL1SL1TSL1T-XSL1A.pdf it is the manual totally free pdf format toyoto serger 6600
Apr 05, 2012 | Toyota Sewing Machines
Serger tension is off and I can't get it adjusted properly. I have a Necchi Lock machine that is 25 years old and it's been a gem. Do you know how to adjust the tension?
Do you still have the instruction manual for the machine? If you do, you get a great big gold star!
Unless this model has auto tension, there should be a tension knob or lever on each thread feed.
Open the tensions (set at zero). No access to the tension controls, raise the presser foot and this will open the tensions, if the controls are okay.
Re-thread the serger and then set the tension controls back to mid-range or lower the presser foot to re-set the auto tension function.
With the presser foot down, stitch a chain of threads and if they do not "knit" as the should - the serger needs to visit a repair shop.
Service for a serger usually begins around $100.
It could be just the timing needs to be adjusted.
If the tension controls need new springs or the controls needs to be replaced, this will add to the repair cost.
Mar 29, 2010 | Sewing Machines
The threads are not tight on my serger
Here is an easy way to get your thread adjusted. Rethread the machine using four different colors. Then sew and for example the "yellow" thread is loose on the fabric, you know to adjust the tension with the yellow thread. Also a good starting place on your dials is 4-3-2-1 from left to right. Start with the tension set there and then adjust as needed.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
118 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
