My brand new washing machine does the wash cycle but the water doesn't pump out when finish
    Top Expert:
  • Washing Mach... Master
  • 40,304 Answers
Even though your washing machine is brand new, the pump could have been defective when installed at the factory. Your warranty should cover this.
Posted on Dec 01, 2016
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
If this does not help, the drain pump may be faulty.
Kind Regards
* If this solution helped you, please rate it
Sep 05, 2011 | Kenmore Washing Machines
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
Not washing at all on any cycle
Sorry, sounds like your Circulation Pump is faulty/worn out.
If your machine is not over two or four years old then maybe you have a simple blockage.
If your machine is old, a new pump can be half the price of a new machine.
Hope this helps.
Apr 16, 2009 | LG Dishwashers
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Mar 25, 2008 | Indesit W 123 Front Load Washer
Washing Machine
the problem is the pumping out of the water it be something caught in the pump or the pump is faulty remove it check it out. Close Ireland,bye bye
Nov 21, 2007 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
