Water sometimes doesn't drain. Other times it does. It's like the pump doesn't kick in
    Top Expert:
  • Washing Mach... Master
  • 34,217 Answers
This could be due to intermittent malfunction of the cycle controller.
Posted on Dec 01, 2016
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Duet F-02 code
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
More...
A friends HE3 would not drain. F02 error message was showing. The filter had coins, pencils, a wire from a bra, and a piece of cloth that was stuck in the pump impeller vanes. Cleaned it all out put it back together and it worked.
For others that encounter the same problem: (The fix is very easy).
Unplug the washer. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap. Remove the drain filter cover cap by turning the filter cover cap counterclockwise. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand). Clean the cover cap gasket and the gaskets mating surface. Replace the filter and close the cover cap firmly. Run a short wash cycle and check for any leaks at the filter cover cap. Replace the kick panel if none are found. Good luck.
Sep 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kemore elite he 3t front load washer it won't drain and its giving me a F02 error message. what does this mean? Help!
it's a long drain error code,most likely the pump is blocked with all kinds of good stuff,coins, screws,and who knows what else,vac out all the water with a shop vac, and next time open the door,look around the opening where you put the clothes into the washer and you'll see a tag with the model and serial numbers,just need the model number,remove the bottom panel,look at the pump,if the center part can be removed,turn it slowly counter clockwise until the water starts to leak out and stop and vac up the water as it leaks out,do this until it's empty and then remove the center catch piece of the pump and clean it out,stick your finger in the pump and make sure nothing is stuck in the impellar,also check the rubber boot part of the hose,sometimes stuff is still in there,if the center of the pump doesn't come out,pull off the hoses to the pump and check them for junk in them and check the pump,reconnect the hoses,fill with some water and put in a spin cycle,if the water still doesn't drain out most likely you'll have to change out the pump.
Aug 16, 2011 | Kenmore Elite 45986 Front Load Washer
Burning smell with ticking noise water in bottom but not spraying or draining.
you may want to remove bottom kick plate if you look in there you wil see the main pump housing and to the left is a drain solenid that has a actuator allowing it to move up and down and this is what opens the pump to drain and pump.... alot of times this solenoid will go bad and sometimes literally melt and get stuck causing the odor you are describing and the problems....hope this helps good luck and please vote.....
Jan 03, 2011 | Maytag Dishwasher
My model wdc1025 will not drain wash water or rinse water
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance. Hope this helps...
Daniel
Sep 02, 2010 | Splendide Washing Machines
How to clean water pump
Hi
To resolve the issue you’ll need to then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. In case you need more information then please post back with the make and model number. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Washing Machines
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
Jul 15, 2009 | Kitchen Appliances - Others
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
