Question about Exercise & Fitness
Error message E02 on Reebok RK8 Threadmill - please help if possible
Threadmill stopped working while in use and set off the trip switch in house. No power going into machine after this and would not turn on. Replaced fuse and power back into console. Will start the countdown but when machine should start to function it beeps and error E02 shows. Any help would be really appreciated.
  • 18 Answers
SOURCE: E02 Code
Faulty heating element, or main eprom is faulty
Posted on Jul 12, 2007
sir fixalot
  • 146 Answers
SOURCE: I receiver error number E000067-0110
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
Posted on Jan 02, 2008
SOURCE: Replace Switch error message
It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
Posted on Jan 27, 2009
SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Posted on Apr 17, 2009
  • 811 Answers
SOURCE: Rear lamp failure and Coolant Sensor Bad Error Message
unhook battery for 10 minutes then reconnect
Posted on Sep 12, 2009
I discovered Whirlpool hot water heater was displaying E02 error code. Followed directions in manual to possibly correct problem, but E02 code continued to be displayed. What is the remedy for this?
Error E02 indicates that the water temperature exceeded high limit.
Switch off the house circuit breakers dedicated to the water heater and then press the reset button located behind the control panel on the water heater.
Switch house circuit breakers back on.
If error persists, call a service engineer.
good luck
Jan 05, 2018 | Whirlpool Water Heaters
What's error code e02 Whirlpool water heater product # 100028736
E02 Water temperature exceeded high limit Switch the two house circuit breakers dedicated for the water heater to OFF and then press the reset button located behind the control panel on the water heater. Flip the house circuit breakers to the ON position. If error returns, call a service technician for assistance.
Dec 24, 2016 | Whirlpool Washing Machines
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
My SMS68M02AU Has an error E02 please help
That error is a temperature sensor error and the repair process is quite involved.
Apr 17, 2016 | Bosch SMS68M02AU Dishwasher
Reebok premier running machine (re-11301) keeps tripping electrics... Loose earth wire located near to on off switch... Where does it fit... Wiring diagram required.. Please help
Dear Sir:
See this block diagram that i did for you help.
5_9_2012_10_31_52_am.gifyou will only 2 wires, one go to the input the another to output it does matter which color go to the input or output.God bless you
May 08, 2012 | Reebok Exercise & Fitness
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Mar 27, 2009 | Reebok Exercise & Fitness
Proform 860 QT doesnt have power
There's a little breaker near the main on/off switch that has tripped. Re-set the breaker. (also check the main on/off switch, typically near where the power cord enters the treadmill...
Mar 13, 2009 | Exercise & Fitness
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
