Question about Samsung Televison & Video
Will my wifi antenna work on my samsung smart tv for better wifi reception
    Sergeant:
  • 246 Answers
Reception will be due to signal not tv
Posted on Dec 02, 2016
I have a Samsung tv, model # LN32A550P3FXZA. I've been trying to hook up an antenna but so far can't get good reception. Could the problem possibly by my tv tuner? Too old or bad?
Sounds like you're in the fringe area of the antenna. Depending on how far you are from the broadcast antenna, You may have to increase the length of the pole that antenna is on or get an antenna that has a greater range in miles. Digital signals are real picky about antenna aim. If you have a long cable between the antenna and the TV, you might try an inline amplifier.
Oct 19, 2017 | Samsung Televison & Video
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
How do I connect to wifi?
Setup menu - WiFi - LAN - Network if this does not work try going to web browser to get an error message.
Samsung 3D LED Smart TV Setup menu WiFi LAN Network
Mar 14, 2016 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Fm antenna
hahahah that's low reception try to connect into tv antena much better reception.
Aug 10, 2013 | Samsung HTC550 Theater System
I get bad reception with my TP-Link PCIe Wifi Card! What can i do?
Often times the antennae on these routers come loose. Ensure that the antennae are firmly plugged in.
Try also changing the channel. Routers have 11 to 13 possible channels and most default to 1 6 or 11. Try a different number to reduce interference.
Physical construction of your house can hinder wifi reception. This is often subjective and your best bet would be to move the router around the room or into a different room if possible.
Feb 28, 2011 | TP-LINK 11b/g Wireless Adapter
My reception is not crisp clear. I want to know
Are you on antenna or cable?
Some tuners do not work all that well on the TVs, if your old TV worked alot better with the same antenna then it may be a matter of using a VCR or external tuner then feeding the video into the new TV.
Cheers,
Jan 06, 2010 | Televison & Video
What is smart antenna for the convertor box?
Smart antenna is a device that connects to the antenna, and send information on the channel received, adjusting itself for the best reception of that channel.
See below :
What is smart antenna? - a definition from Whatis.com
Smart antenna - Wikipedia, the free encyclopedia
Smart antennas
Sep 10, 2008 | RCA Televison & Video
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
Internal Antenna not working anymore
if you do a search at pdaphonehome.com a guy has replaced his antenna and provided step by step instructions for how to do it yourself with pictures. I don't know if frying it can make sure getting a new antenna will fix that but thats something you can try before replacing.
May 12, 2007 | Samsung SCH-i730 Pocket PC
Open Questions:
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
