Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
I get problems loading my instalation disk .
I have loaded the card into computer then i try to install the disk and it keeps saying it needs drivers that should be on the disk . can u please help me?it is version 3.3b
    Problem Solver:
  • 14 Answers
Re: i get problems loading my instalation disk .
Try and go to the manufacturers website and downloading the latest drivers from them. Sometimes they have trouble with the drivers on the cd but obviously can't recall every cd, so they release the updated drivers online through their website.
Posted on Nov 20, 2007
0 characters
3 Points
Loaded the program but windows 7 says no driver loaded and will not reconise the video2pc device
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 24, 2011 | ION Audio VCR 2 PC USB VHS Video to...
I am having problem doing installing drivers of philips tv tuner card xpert TV7134. i am using os windows7 64Bit, when i start loading driver this error interrupts me SAA7134 WDM drivers loading failed! i...
Is it 64 bit compatible, if needed try to source drivers elsewhere or a little trick i have learnt is alot of xp drivers work in windows 7 if manually installed, if you can do this give it a go or let me know and ill give you instruction, was the card certified for vist, if si try to get the vista drivers and give that a go, hope this helps
Nov 15, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Fail to initialize
be sure to load the correct driver for it- try reinstalling the driver
Oct 12, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I bought my pc tower used from a co-worker, and he no longer has the installation disk and doesn;t remember what e-mail he used to register it. I pulled the Pinnacle card from the board and got a 19...
The number that the install program needs is the software serial numberthat was on the jacket of the install disk. The drivers for the card should load without a serial number, but the main application needs it. Check with Pinnacle support, but I suspect you will need to purchase a new copy of the software.
Oct 08, 2009 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Problem in recording and using the remote
this is only a wild guess, change the battery of your remote, i once use a tv tunner and the only problem is the battery from the remote
Sep 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have problems loading my wintv version3.3b
first down load the update. when you get that open the zip file. then look for hcw clear.exe and click it . it will clear every thing and ask to reboot. then cancel all devices found after reboot. open the folder and click hcw drivers install, when that is done then click setup. hope this helps
Nov 20, 2007 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
XTV2.0 software says "Please install the XTV2.0 Hardware Device"
Windows is installing the wrong driver. If the driver is loaded in the Device manager list ( /Sound, Video and Game Controllers ) as USB2821 then the wrong driver is loaded. It should be loaded under Imaging devices as XTV2.0. If this is the case right click on the USB2821 device and reload the driver again from the CD under "XTV20\Driver\Manual and select "EMVIDEO.INF" or from from a different location`until the correct driver is loaded. It won't work until the driver XTV20 is loaded under (Imaging Devices).
Mar 06, 2007 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
my computer hang everytime i install enltv.i follow your steps but it also hang.what should i do?pls help me..
here's my email add
Nov 29, 2006 | Encore ENLTV-FM-HA (CTETVC)
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
77 people viewed this question
Top Hauppauge TV Accessories Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Luc Francoeur
Luc Francoeur
Are you a Hauppauge TV Accessory Expert? Answer questions, earn points and help others
