Question about OKI C5500n Laser Printer
Oki c 5600 980 fatal error
980 fatal error It* is giving Do you help
  • 22 Answers
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Posted on Jul 27, 2009
SOURCE: How do i solve fatal error 980
If you have 980 fatal error and have checked that there is no paper stuck in fuser or you have removed the paper and still have error, then you should contact Oki, there is a fix for this exact problem, if you contact them they will send you a patch which you will need to run on the printer. This will fix your problem
Posted on Mar 02, 2011
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: does anyone know what is
According to the Oki service manual that problem is related to the fuser. The reference is that there's some media stuck in the unit, they recommend replacing the fuser but it's possible just reseating it with power off will allow it to clear the code.
Posted on Apr 21, 2008
SOURCE: OKI C5900
we have the same problem but with Oki c5500
Posted on Jun 21, 2008
SOURCE: SERVICE CALL ? 980 ? Fatal Error
I was able to reset my Fatal Error 980 code on my C5800. There is only two wires coming from that connector and not four at the bottom of the fuser. That is pin 2 and 3. 4 and 5 is still the fuse but there are no wires there, just the 2 pins. What you have to do is make a fuse by connecting pin 4 and 5 together with a piece of wire and break the wire after a few seconds after powering up. This will reset the Fuser counter back to 100%. DO NOT DO THE NVRAM RESET, THAT WILL ERASE YOUR NETWORK FEATURE. Here is the step by step of what I did.
1)Take out the Fuser and lay the two blue levers flat and remove them.
2)remove the two silver screws and separate the casing.
3) Remove the two black screws from the connector at the bottom of the fuser closest to the edge.
4)Unravel and loosen the wires so you can pull that connector out a few inches so you can get a couple of wires in there. You will see what you need to loosen to get the connector out far enough, really easy.
5)Insert a wire into each of the two holes on the back of that connector. Its pretty simple to see where they go, 2 and 3 have wires going in, 4 and 5 dont which is the fuse. After you get the wires in the 2 holes, check for continuity from the end of the wires and the terminals if you can. Make sure the wires are long enough to hang out the case. Use the thinnest wires you can find.
6)Run the wires out of the case and put the case back together and put the fuser in. Twist the two wires together and power up the machine. As soon as you here the first motor,which is about 5 seconds, pull the wires apart and BAM, you just reset the fuser back to 100% and cleared the "980" Fatal Error. You could always put a miniature fastblow fuse in instead of using the wires but that would be tedious to me.Good luck
Posted on Jul 12, 2009
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
SERVICE CALL 188 : FATAL ERROR
Service Call 188: Error: Sub-CPU Communication Error
1- Check the connection of the S2M board.
2- Replace the S2M board.
If the problem does not go away after a reboot you'd better call Oki (it should have a 3 yr. waranty) or an experienced oki technician.
This is not something you should want to fix yourself. The replacement of the s2m board is not an easy task (even for an experienced mechanic)
Jun 24, 2008 | OKI 9800hdn Laser Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
OKI C5500n Laser Printer Logo
4,770 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
