Question about Polaroid FLM-3732 Television
Hi. When I turn on the tv after being off all night, it has a
High pitched screech for 3-4 mins. That's been going on for about a week. Now to add to the, the picture's color fades to green and becomes foggy. Please help..........
Thanks,
Jerry
  • scljjn1 Jul 20, 2009
    Hello. What happens is when I turn on the tv, the volume is a high pitched screech. I have to mute the tv volume. It goes away after 3-4 mins, but I fear this is going to get worse. It started out a week ago and only screeched for 1/2 a minute. Also, when I change channels the picture become green with vertical lines. That is now fading in and out when I am watching a show, not just turning the channel.
    Thank you so very much,
    Jerry
  • Rommel Cana
    Rommel Cana May 11, 2010
    hi, what exactly your brand and model of TV?
MNfisherman
  • 11896 Answers
SOURCE: High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Posted on Jul 22, 2009
SOURCE: screeching sound and display of color bars with no picture
it is two 1000uf 10 volt capacitors on the power board. the tops of the
capacitors will look like they are bulging. total cost of parts around
five dollars. if you can use a soldering iron and have a half hour to
spare this will fix it .there are alot of polaroid customers that have had
this problem and fixed it themselves. just click on the follwing to see
the video on this fix http://www.youtube.com/watch?v=unuS3CvmWtw
Posted on Sep 05, 2009
techman007
  • 1112 Answers
SOURCE: Polaroid 3700 lcd (2006): Every time it is turned
Hello: This is a problem with the power supply unit, There are two capacitors that need to be replaced in this unit. They are the two 1000uf 10V Capacitors that is failing on the power supply, If you take off the back there is a metal module in the center of the unit, lf you open it the power supply is located towards the upper part of the system. Look at the capacitors for puffy and swollen tops, just in case you don't know what capacitors look like they look like tall batteries mounted vertically on the board with metal type tops. If you run your hand across the top of them they should all be flat. Look for the two swollen ones and replace. The Value on the Capaictors should say around 1000uf at 10V. Replace with 1000uf at 16V. The reason you television is malfunctioning is that these caps are leaky.
Posted on Nov 08, 2009
Testimonial: "Your solution was exactly right . The only thing that was confusing was the part about the capacitors being mounted vertically . It is fixed. Thank U "
lovejoy91
  • 691 Answers
SOURCE: when the TV is turned on there is a high pitched
You have bad filters in the Main Logic area
Posted on Dec 09, 2010
SOURCE: green tint and psychedelic color swirls in picture
my Polaroid FLM373B picture color is psychedelic blue -greens
I have replace the power board caps 1000uf 10v and 1000uf 35v
that did not help.
I've read that it could be the T-CON board now what is that
Posted on Aug 03, 2011
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
HI Pitched Squeel
Please Post your Make and Model number printed on Back of TV.
May 11, 2010 | Televison & Video
What could be causing a high pitched screeching sound when I turn on my single handle shower?
If you haven't turned the main back on, this could cause the sound.
Re supply the water to the lines.
May 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Screeching noise
rear drum bearing needs to be replaced
Sep 25, 2009 | Maytag Dryers
Jul 22, 2009 | Polaroid FLM-3732 Television
Turns on then gives a High pitched Screech then shuts down even after totally unplugging it and reconnecting it blinks on then Screeches then turns off rinse repeat
are you talking about just the monitor of the computer as a whole? if you are talking about the computer then, there is something loose inside the case, which is causing the high pitched sound.
Jun 27, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Laptop gives off a high pitched screech ONLY upon start ups
Assure there a no disks in your CD/DVD drive
Make sure there is nothing blocking the fan
Feel the base of you laptop and assure it is cool
Do not block off air flow
Event Viewer: Click the Start button . In the Search box, type Event Viewer, and then, in the list of results, double-click Event Viewer.
Go to the Sytem Tab - Look for any errors that seem noteworthy
Post your results
Jan 07, 2009 | Sony VAIO VGN-NS110E/L Notebook PC
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Televison & Video Logo
57 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
