SOURCE: XEROX DOCUCOLOR 5750 PROBLEM
That means your waste toner sump is full and needs emptied and vacuumed.
For that problem, yeah its workt fixing.
SOURCE: FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
SOURCE: machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
SOURCE: when i switch on the machine,error E000002 is comming
E00002 on iR3300 is problem on the heater assembly. Replace heater assembly and buy new heater assembly. Good Luck...!?
SOURCE: Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
