SOURCE: 2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
SOURCE: Windows XP will not recognize Garmin 200W
I had the same issue. I would plug it in and it would recognize the device then it would disappear.
What I did to solve the problem was to first turn on my Gamin 200w. After it was finished loading maps then I plugged in in to the usb port. My machine recognized the device without any problems. I am running Windows Vista Home Premium. Hope that helps.
SOURCE: how can I update my garmin 255w for free?
Garman gives you one free update for maps - if you download them within 30 days. Otherwise you have to pay.
To find out what you need. Use the usb cord provided with the unit and plug it into your pc. Go online to the GARMIN website and download the manager. From there it is just follow the prompts. You might Email and ask GARMIN to give you one free update for maps? The firmware updates and other updates such as POI are free.
SOURCE: can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
SOURCE: Garmin Nuvi 1450 is not
Have you registered your device at Garmin and downloaded the latest version of Garmin Updater? Also connect the usb cable directly to a port on your computer and not thru a usb hub.
I have attached the link to Garmin. thanks for using FixYa.
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
