Question about Siemens H 4680 BP KAT Stainless Steel Electric Single Oven
We have a Siemens type S2S-500N2 electric meter box in the flat where we just moved in. Could you please help me with agents that do sell the tokens for the box. Its a card that needs to be inserted with a magnetic strip on the back.
I live in Bendigo and need a repairman for my Finesse Duo Electric oven. Can you supply a contact here please ?
look in the yellow pages
one electrical repair agent on the net is---www.charltonbgo.com and they are in the yellow pages
they are agents for a wide range of electrical units ( 22 listed ) and could advise you as to where you can get it fixed if they are not the agents
Oct 25, 2016 | Ovens
My oven will not unlock.
Either unplug or turn the off off at the breaker. It may clear the problem. This happens a lot after clean cycles. Sometimes the electronics fry due to high heat, so try not to use self clean very often.
If this doesn't work, leave comments with your oven model and type of lock if you know. The instructions for opening a stuck lock depend on which type of lock you have: solenoid controlled buzz when setting or unlocking and have an arm you move to engage the lock. Heat sensitive locks have an lever you move to lock and un-lock, but don't make noises. Motorized locks don't have handles or levers, and lock by themselves. Thanks for your question, I hope the first instruction helps.
May 08, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I need to take the door off - any ideas
A lot depends on the type of hinges fitted to your oven door.
Try this link, it should help you .www.youtube.co.uk
In the search box type, replacing oven door hinges
Please let me know if you were successful .
Thanks.
Barkencoa
Nov 25, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
I live in the UK and I have a Hotpoint over which did not come with an instruction manual when I first moved into my flat. There are three knobs on the oven: one for time, one for temperature (in degrees...
I have the solution for you.
In your browser bar type in hotpoint user manual
Then click on hotpoint manuals, user guide in the drop down list
Then type in the relevant details in the boxes provided.
Then you can download it to your hard drive, or to your printer as req'd.
This will give you all the info you need.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Hotpoint SY36 Style Line Stainless Steel...
How to get oven door on wirlpool electric range
Try this;
In yout browser bar type in uk.youtube.com
In the search box type in Fitting oven door hinge
Then click on appropate video.
You may find this helps.
Please leave comment to let me know if you found this helpful.
Thanks.
Dec 30, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Fan working grill working just no heat in siemens oven
hello the first thing that we need to look at is the electrical box thats is outside and see if there are any more braekers tripped. the clue is that everything work except the heat. thats 208/230 volt and the rest of the oven is 115 volt. e sure to take the breakers and push them all the way to off then back to the on position. if thats is the problem now you are going to have to call a service man to check out what is shorting and causing the breaker to trip.
Dec 23, 2008 | Ovens
Smeg oven model 280X
Found the local agent for this cooker and they have supplied a copy of the operating instructions.
Thanks anyway.
Sep 08, 2008 | Smeg SE280X Stainless Steel Electric...
Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Jul 22, 2008 | Maytag 30 in. Electric Single Wall Oven...
Siemens H 4680 BP KAT Stainless Steel Electric Single Oven Logo
129 people viewed this question
Top Siemens Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Siemens Oven Expert? Answer questions, earn points and help others
