Question about LG Vu CU920 Cellular Phone
CHANGE TIMING OF LOCK ON KEYPAD - LG Vu CU920 Cellular Phone
I have a schlage camelot leverset and i need to change the code. its a 4 digit code...How do i do this? thanks
No problem!
A quick note: The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock, which i noted above. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Also, you will find "Keypad Programming Guide", etc. links which are PDF type files, giving you a "picture" of the print instructions.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck,and please provide feedback if this helps!
Aug 17, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
Want to change entry code on lock./
Reprogramming FE 375:
This link will take you to the page you need, to get started:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Aug 06, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Is there a setting that I can change that will keep my keypad from automatically locking? I have the Nokia E71.
Hello and Welcome to FixYa!
To change the settings of keypad auto lock of your Nokia E71 and to make it automatic. Follow the given steps:
Go to Menu >> Tools >> Settings >> General Settings >> Security Settings >> Device and SIM card security >> Phone and SIM card >> Keypad auto lock period
Here you can set your keypad to lock automatically after a defined period.
I hope this solution helps you
Feel free to let me know if you have any questions
Thank you for using FixYa
Jul 16, 2011 | Nokia E71 Smartphone
How to change the font style on nokia e63 and how to change automatic keypad lock settings..i dnt want my keypad to lock by itself
Welcome to FixYa
Dear user
Here is the solution for you.
Tools > Settings > General > Security > Phone and SIM Card > Kaypad autolock period > Change > None
Settings->Display->Standby Font Colour.
Hope this helped...Thanks for connecting FixYa
Apr 06, 2011 | Nokia E63 Cell Phone
Need to change code.
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
Jan 29, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I lost my instructions to change the keypad password, can you please instruct me on how to change this password?
Jan 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Locked out of the phone its self i465
if the automatic keypad lock is what concerns you about, you can change its setting to manual keypad lock. you can access it at its phone menu settings. navigate to the menu until you will find keypad setting option or the like...
Jan 01, 2011 | Motorola Mobility Clutch i465 Cell Phone
I have a schaeg BE365 and i would like to change the coad
Nov 14, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
My function key is on and i cant figure out how to turn it off
To use the embedded keypad
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
(in the top row of the keyboard) to turn number lock on or off.
When number lock is on:
• Keys change to the numeric or arithmetic designations printed on the right side of the
keys in the numeric keypad area.
• The Num Lock status indicator is lit.
• To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
http://h10032.www1.hp.com/ctg/Manual/lpi05379.pdf
Page number: 30/141
Regards,
Nags
Jan 19, 2010 | HP Pavilion N5415 Notebook
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
LG Vu CU920 Cellular Phone Logo
66 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
