We've been getting rusty staining on our clothing lately; when I move the empty drum when it's not running it sounds like there is water sloshing around under it. We've also noticed a musty smell .... seems like it isnt fully draining the water out after a wash cycle... please help
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains.
Just remove the dispenser and wash it our very well and the problem will be gone.
I don't think the washer is at fault; the clue is 'Used very little.' I think the rust is originating in the water pipes serving the washer.
The only help there is to run one machine with no clothes in it (wasting water) or putting splitters on the faucets and flushing the lines into a sink or other drain.
To remove rust stains from WHITE (!) clothing and many synthetics, buy a product named 'Whink.' It is available in many drug stores, super markets, etc. in the area where one finds other laundry items.
It is fairly safe to use (with precautions) but keep out of reach of kids.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
no not any filter this will more then likely bearings leaking grease that is packed into it just c if your inner drum moves up or down by placing your hand on the outer part of the inner door and place your fingers on the inner drum now lift your fingers up if it does move then your bearings are starting to collapse which is quite an exspensive job average price £125.00 to replace the bearings but if this washer is still under guarantee then get them out and thats what the stain comes from and it will alwys do it also if it doesnt move it can still be a bearing problem that its just leaking through the rubber seal and the bearings are fine eva way it comes frim the bearings m8
Are stains a brown rusty color? If so, this may be an indication that the rear drum bearing is going bad. The bearing itself cannot be replaced. You will need to replace the entire back shell of the wash tub. Hope you have a warranty. This can be an expensive repair. Let me know if this is the case.
Have you tried Calgon to get rid of limescale deposits?
Also have you used any laundry bleach at any point, because it stays in the machine for ages and clothes come out with faded patches and bleach marks for weeks afterwards.
