Question about Proscan 42LA30H 42 in. LCD Television
PROSCAN 42LA30H I'm trying to get my xbox 360 to run in high def.can anyone tell me the compatabilities of my PROSCAN 42LA30H LCD TV. or how to get it to work? thank you............................pp
Go into the dash board and try changing it there...?
Posted on Nov 30, 2007
0 characters
3 Points
No screen proscan 42la30h
Lcd/Backlight! Main Problem On the led,lcd is the Bad lcd ribbon or Bord, Try turning off all the lights and Turning it on, then kneel down to the ground and see if u can see Channels changing when u click up/dwn or volume or even the Fuzzy look when theres no cable going to it. if u can see then its probably a bad board or chip.
Hope This Helps :)
Mar 08, 2012 | Proscan 42LA30H 42 in. LCD Television
I can not get my component video to work for my xbox 360 with my with my Toshiba 36A43 Television
Do you get picture at all? What is your resolution setting on the Xbox? That TV is Standard Def. Plus on the plug that goes into the Xbox there is a switch for HD and non. Check and see if its swtiched over to HD. If the Xbox is trying to run in high def on a standard tv you will get no picture. Especially using the the little switch on those component cables. Hope this helps!!
PS...If this does help you please rate my level of help...Have a good day and good luck =)
Apr 23, 2011 | Flat Panel Televisions
Does the Proscan 47" LED
yes it does , if you are viewing the TV from the rear it is located in the back on the lower right , on the right side of the RCA's . here is a link to give you a visual , just wait for the manual to pop up .
Jan 28, 2011 | Proscan 42LA30H 42 in. LCD Television
Trying to program my Directv (tivo) remote to new Proscan 32" tv. The codes from directv don't work. Any suggestions?
I read another post where they added 1 to make the code 5 digits. Use 01331 and try it, it worked on my Directv Tivo remote and Proscan 32".
Aug 01, 2009 | Proscan 42LA30H 42 in. LCD Television
Have 40 inch Proscan TV. Am trying to program my Verizon (FIOS Service) Remote to recognize the TV. None of the numbers furnished by Verizon work. Proscan gave me some weird numbers that do not work...
You mostly have to go through all the numbers to find one that works. Sometimes, with an off brand TV I have the best plasma i've ever owned right now. It's not a fancy brand name and the remote ( Comcast ) wont work for it. The comcast guy said that it would not work with my TV. Hope ite helps. You may not be able to pair the two at all.
Jul 17, 2009 | Proscan 42LA30H 42 in. LCD Television
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Jul 08, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
Here is the link The brand is now owner by oncorpus.
Aug 03, 2008 | Proscan 42LA30H 42 in. LCD Television
Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Feb 29, 2008 | Proscan 42LA30H 42 in. LCD Television
Proscan 42LA30H 42 in. LCD Television Logo
255 people viewed this question
Top Proscan Flat Panel Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proscan Flat Panel Television Expert? Answer questions, earn points and help others
