Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
2 Year old Samsung 46" DLP TV with white dots on picture
Problem started in June and is multiplying rapidly.
Not sure what is causing it...
Does anyone know if it has anything to do with the REPLACING THE BULB?
SOURCE: Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Thanks for your solution. This is a problem with color wheel. I could not fix it by myself, so my friend will try to fix it next week.
Posted on Dec 11, 2007
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
SOURCE: Numerous white spots on Smasung DLP TV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Posted on Apr 07, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Posted on Jun 28, 2009
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Posted on Aug 20, 2009
My Mitsubishi TV has a small white dot on the screen
This could be something on the lens or mirrors. you can open one or both porthole covers on the left or right side of TV to determine if this is the cause. You can look at the mirrors & lens to determine if a bug or dust has gotten on either part. Then clean.
HOWEVER, the most likely cause is the DLP chip. this causes white & or black dots. May start out as one or two, then multiply.
See the following website for the proper DLP chip for your Mitsubishi model#:
http://www.shopjimmy.com/catalogsearch/result/index/?cat=24&q=dlp+chip
Jul 09, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp white dot
If the white dot is on every picture and every input and stays there for a sec. after you press the power button to turn off the tv then suspect a stuck mirror in the DMD.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My samsung tv white lights popping up on monitor
Yes if you replace the Light Engine,this is a very high dollar part! call UED for rebuilt price 1-800-648-6657
Sep 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 42"DLP has dots of light on screen
try cleaning your screen the holes
that you see on side of set is whear you clean.it
go to walmart and buy lcd cleaner and that should work.
but if still thear your eng block is bad
Aug 12, 2009 | Samsung SP46L3HX 46" HDTV-Ready DLP TV
White dots on 50in dlp samsung
This is caused by dust or dirt in the Optical Block. Only a good TV Tech can solve this problem.Call one for an estimate.
Aug 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on samsung dlp
HI, these are the signs of a failing light engine. you will need to replace this engine soon. these distortions will worsen over time.
Jul 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on my samsung dlp tv
Samsung DLP Projection Tv white dots may caused by DLP Chip. Change a new DMD Chip 19106143W. The post show you how to replace it step by step.
Your chip should look like this:
Jul 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Have little white dot's on screen will changing
Highly unlikely the bulb could be at fault; it sounds a lot like a defective DLP chip. If you are not aware of how this device functions, it is an array of physical mirrors which can fail individually and cause the effect you are having. The bulb failing would cause a loss of the entire screen, not just a few points.
Jul 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Jerry Greenberg
Jerry Greenberg
