Question about HP Pavilion dv4000 Notebook
Recovery options onboard hard drive
When I turn on my computer the HP logo comes up, but the computer then goes to a black screen with a blinking curser on the top left corner, after blinking for a while the message: " the disk cannot be read Press Ctrl + Alt+Del to restart" This message continues to occurThe hard drive test : #1-06 Fail
Your hard drive is bad. That is what the SMART test is telling you. Replace the hard drvie.
Mike
Posted on Jul 22, 2009
  • 520 Answers
First check to see if your hard drive is seated properly..
if ok try to access dos prompt at start (f8 )
try startup in safe mode
try repair disk with checkdisk (chkdsk)
in a dos prompt
if all fails your drive probably has bad sectors or missing sys files or otherwise corrupted...
download a prog called spotmau(free to try)...
create a boot disk with the software(everything is part of the package to show you how)
once you have a boot disk startup pc with bootdisk in cd drive....
when software starts you will have many options to repair almost anything that can go wrong.
the only better software for repairing damaged disks is hdd partition which will repair the most difficult to fix disks(hd)
Posted on Jul 21, 2009
How do I reset my hp pavilion 23-h052 touch smart all in one desktop back to the factory settings
From HP's website:
1. Turn off the computer. If necessary, press and hold the power button until the computer turns off.
2. Disconnect all peripheral devices from the computer except the monitor, keyboard, and mouse.
3. Press the power button to turn on the computer.
4. As soon as you see the initial company logo screen appear, repeatedly press f11 until the
Windows is Loading Files message appears on the screen.
5. Select Windows Recovery Environment.
6. Follow the on-screen instructions.
7. When the recovery is complete, turn off the computer, reconnect all peripheral devices, and then turn the computer back on.
http://h10032.www1.hp.com/ctg/Manual/c04329428
Jan 30, 2015 | HP Computers & Internet
Cant get to boot screen to start recovery on e525. I tried every f key! Only get e logo screen which will flash to a black screen with blinking cursor at top left then flashes to all black screen back to...
Some of the emachines coming with Recovery image. You need to press F11 key on starting to check whether the image is available or not. If it is there proceed with restore.
Otherwise you need a recovery CD to do this. If you don't have any CD then you could purchase the recovery disk for your emachines from the link below by entering the serial number on your computer:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Apr 02, 2012 | Acer Computers & Internet
Black screen problem
it appears there is a high level of data corruption on your computer's hard drive sadly you must reinstall the windows OS however i do recommend using Ubuntu to access your files while in live cd mode by clicking try ubuntu or use mini-XP (a mini version of windows xp) and use an external drive or mega.nz (mega.nz for free can store your files up to fiffty gigabytes)
Apr 17, 2017 | Computers & Internet
I cannot get my computer to boot. It just goes to a black screen after the acer logo and then the Microsoft loading screen comes up and then goes back to the black screen and that's it. I tried system...
This is a hard drive issue, remove hardware and reseat it back into place, sometimes this will work and run fine. But it is more than likely your hard drive will need to be replaced.
Mar 06, 2012 | Acer Computers & Internet
My emachine laptop has a virus. When you turn it on it goes to black screen with the option to start recovery mangement or start windows.When pressing either,it goes to black screen for a little bit then...
You may have files that you want to keep that you saved on your hard drive, but if you haven't backed them up then you will have to lose them because the only thing you can do to fix this is use the factory recovery disk which will wipe your hard drive clean.Just put the disc into the disc tray and you should get an option to start the recovery disc when you turn on the computer, it will tell you to press a key to start it which might be f3 or something different, I'm am not sure what key but when you have done that you should be able to start the recovery and wipe the hard drive clean and it should solve your problem
Oct 29, 2011 | E-Machines eMachines Desktop PC
When I turn the power on it starts up but just shuts down ten seconds later and keeps starting up and shutting down over and over again
This may be a hard drive issue, remove the hard drive and power up the computer it should show the HP logo and go to black screen with a blinking cursor, turn off and re-seat the hardware back in place and restart the laptop, any change? if the same, reload the recovery disc if available this will prove if it's a software issue or hard disc problem. If there is no improvement the hard drive should be pulled and tested at a computer shop before buying a replacement.
Feb 13, 2011 | HP Computers & Internet
One minute it was working fine, the next it was a black screen with the cursor blinking in the upper left corner. I tried re-booting it, but it just goes back to the black screen with blinking cursor. Any...
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
Dec 18, 2010 | Acer Aspire One PC Notebook
Computer startup problems
Likely the hard drive is bad. I would suggest testing the hard drive or having a technician test the hard drive, replace it if it is bad and restore your operating system
Jul 08, 2009 | Gateway M-6750 PC Notebook
Hp pavilion zv6000..Please HELP!!
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Mar 15, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Recovery options onboard hard drive?
when you start up the computer at the very beginning when it shows the logo it should have the key to press for system restore at the bottom of the screen usually on HP's and Compaq's its F11 at startup
May 28, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
274 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
