SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
SOURCE: Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
