My laptop hp pavilion dv9700 cannot open my SD card
Every time i try to open an sd card windows explorer turn not responding, at the end i can see the card icon but i cannot open it, i told to even the hp costumer service, they couldnot resolve the problems, curiously i can open the same card in others computer
HPmodel 2000 notebook SD socket won't respond
First - try different SD cards to be sure it is not the card at fault. I assume it is showing up in Windows Explorer - it should be shown as a Removable Drive with a drive letter - on mine it is G: - Note that autoplay might be turned off, so any inserted card may not pop-up automatically. Assuming the card is fine and it fails to show up in Windows Explorer, or if the drive itself is not in Windows Explorer, look in the device manager to be sure the SD reader device is being recognized by windows and if it is enabled - if it says disabled on not working properly, try to reinstall the driver. In my device manager, it shows up under Disk drives as a multi-card USB device and under Portable devices, it shows up as G:/. Alternatively, go to the HP site and see if there is an updated driver - if so, download and install that, reboot and test it again. IF these all fail, it could be a hardware problem.
Feb 10, 2016 | Computers & Internet
What is the SD MS/Pro MMC XD slot used for?
This is where you would take the sd or xd card out of your digital camera and place it in the slot to download the pictures from the camera to the computer.
Another way of getting pictures from the camera to the computer is that most cameras come with a cable that connects to the camera and the other end to one of the usb ports on the computer. Once you have the cable connected turn the camera on and the computer will recognize the camera as a device. You can then search the camera folders for the pictures you want to put on the computer. This way you don't have to take the sd or xd card out of the camera.
May 19, 2012 | HP Pavilion dv9308nr Notebook
My hp pavillion dv4 sd card will not work
Hi
I think you can go to Hp website and go to support download and get the driver for it
Oct 28, 2010 | HP Pavilion dv1000 Notebook
The sd slot doesnt work
SD card might be damaged. Try another one first. If this is not the problem, go to contro lpanel, then system, then hardware, then device manager. Uninstall the sd card reader, then reboot. Windows will find it and reinstall the driver.
Aug 12, 2010 | HP Pavilion dv4000 Notebook
Hp pavilion pc sd card reader not working i
vista just had a update for the SD card reader. Go to Microsoft website and update the driver. FYI Vista is also known for having some problems with the SD card readers in the past
Jan 03, 2010 | HP Pavilion dv1000 Notebook
Copying pictures from laptop to SD card
r u able to see the SD card in my computer if yes chk the free space in it if its empty then right click on sd card icon and formatt it it will erase all the data from ur sd card and then it should copy
May 17, 2009 | HP Pavilion dv6000z Notebook
GPS CAN NOT FIND MAP DATA FILES
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Good luck.
Apr 17, 2009 | Nextar X3-03 Car GPS Receiver
My hp laptop won't read the sd card when I put it in the slot?
Try to reinstal the drivers for your cardreader, select your OP and download the latest drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3224052&lc=en&dlc=en&cc=us&lang=en
Good luck
Dec 02, 2008 | HP Pavilion dv6000z Notebook
SD READER
Check if the device is working
Check if you see the device in your computer ("removable disk")
Try using another SD Card
If not working
Try reinstalling the driver and software to your SD reader.
Uninstall first before reinstall it.
You can get the driver and software at your laptop manufacturer website
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Have a great day!
Pablo :-)
Oct 22, 2008 | HP Pavilion zd8000 Notebook
SD card reader
1) There is SD card reader on pavilion dv 1000, so you need adapter in which you insert mini SD card to make it SD
2) If you have that adapter, check adapter. Maybe it's broken.
3) If your card is biger, like 2GB or higher you may try updatenig drivers (I read on one web page: " There was a software update for support of reading and using higher memory SD cards, for my pavilion ZV5000, on the HP Software update website." )
May 31, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
