Question about GE Ovens
F7 EA error code. GE slide in range Model JCSP42SK2SS.
I am getting an F7 EA error code on this range that has an ERC and touch pad. Have tried disconnect / connect three times. Also tried the ''insulation'' fix and the ''clean the ribbon cable'' fix. Neither worked. Have found information on F7 error codes, but not one that reads F7 EA. None of the buttons on the touch pad work. F7 recurrs after power disconnect and beeps for 10 mins. then stops beeping but continues to flash. Will stop flashing when the stop button is pushed and then the time appears. This only lasts approx. 3 - 4 mins. and F7 EA reappears and beeping begins again. Problem began after oven was self cleaned. Help. Range is only 2 yrs. old and I don't want to have to replace the ERC.
eagle338
  • 4889 Answers
SOURCE: amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Oct 17, 2007
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Posted on Jan 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
Posted on Apr 11, 2010
Testimonial: "was surprised at such a quick response...needed additional information to provide a better solution...very grateful for the assistance"
Daniel S
  • 4323 Answers
SOURCE: i have a GE profile double oven w/ f7 problems. i
Hi
Error code F7 means a stuck keypad button or a shorted connection on the keypad. Try and pull the ribbon cables off the control board, clean the copper connections and then put the cable back and check if error is still there. If error persists then unplug the ribbon cable and let it be unplugged for over 8-10 hours. If no error code after 8-10 hours then it was due to touch pad, however, if the error ode still appears then it is due to faulty ERC. Hope this helps... Please post back if you need further assistance.
Daniel
Posted on Nov 07, 2010
Erroe code f7
F7 means Stuck Button
- Function pad button stuck or
- Bad clock. Try to free stuck button or
- Replace Electronic Range Control (ERC).
Someone mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser.
It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 09, 2011 | Ovens
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double wall oven, model number jkp26gotibb has an f1 error code. Part is no longer available. Is there any other way to fix this problem with out replacing the whole oven.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 16, 2010 | GE Built-In 24" Double Electric Wall Oven
I have a GE Range model JBP85. I have an error code F7. It appears the clock key is stuck. Is there any way to unstick this or any other key? The key pad is expensive to replace.
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Oct 23, 2010 | GE JTP15 Electric Single Oven
Maytag mod che9800bce range use oven get f 7 code
Hello there:
this error code is refferring to the touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
Sep 27, 2010 | Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
I got an F7 error code and now the display is blanked out. JTP20 series wall oven
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Nov 25, 2009 | GE JTP20 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
Monogram wall oven F9 error
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Dec 14, 2007 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
153 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
