Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
I have problems loading my wintv version3.3b
I have installed it then when i tried loading the disk it keeps saying i need drivers that should be on the disk .
please can u help me ?
Re: i have problems loading my wintv version3.3b
First down load the update. when you get that open the zip file. then look for hcw clear.exe and click it . it will clear every thing and ask to reboot. then cancel all devices found after reboot. open the folder and click hcw drivers install, when that is done then click setup. hope this helps
Posted on May 20, 2008
0 characters
3 Points
Which software are you using please give the version
Apr 10, 2008 | Hauppauge WinTV-PVR 350 (WMM32048) TV...
Hauppauge PVR 150 won't work. It used to work,
Did you put in your XP updates before trying to reinstall your drivers?
Oct 19, 2013 | Hauppauge WinTV-PVR-150 (01063) Video...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Windows media center can not find ir receiver
be sure you have installed the driver. If you are using windows 7 you still need to install the winTV driver. I know this because I had the same problem. It should work then. Just go to TV setting in the media center setup and it should scan for channels.
Jul 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hi, you can download the driver for the HVR-1600 from HERE
(53MB FIle)
Step 1 - Extract the Installer
Download the file to a suitable location on your computer, then extract it . Windows has built in support for zip files, if you right click on the file and select 'extract all' a wizard will guide you through extracting the directory.
Step 2 - Remove the previous software version (if necessary)
If you had previously installed the WinTV-PVR-1600 in your PC, browse to the folder you just extracted to (e.g. through My Computer) and locate a file called hcwclear.exe
Run HCWCLEAR.EXE and choose the options Remove All WinTV Drivers and Applications (Total Removal) and Search All .INF Files for Conflicting Hardware.
Note: wait until the black box has disappeared of its own accord before proceeding.
Step 3 - Reboot
Shutdown and reboot your PC.
IMPORTANT! Once rebooted, please do not cancel any 'Found new hardware' wizards. Also ensure that the original driver CD is NOT in the CD drive.
Step 4 - New Driver Installation
After Windows reboots, you will see some New Hardware Found prompts. For each one, please choose the following options:
4A) On the first page, select 'No, not this time' and click Next.
4B) On the next page, select 'Install from a list or specific location (Advanced)' and click Next.
4C) On the next page you will be asked 'Please choose your search and installation options'. Select 'Search for driver in these locations' and then specify the extracted folder (the folder you extracted in step 1).
Note: Specifiy the 'Driver' subdirectory if Windows cannot find the driver file.
Note: You can also click the Browse button and browse for the directlry created in Step 1.
4D) Keep clicking Next for the rest of the steps then Finish to end the Hardware Installation Wizard
Depending on the model WinTV board, you may see several New Hardware Found wizards. Follow the same steps for each.
Step 5 - Run Setup.exe
Run Setup.exe from the extracted folder (from Step 1). You will be presented with a list of things to install, leave all the default settings and click Install.
Once the installation is complete, all drivers will be installed and you should have a WinTV2000 icon on your desktop.
Apr 11, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Problem installing WinTV HVR 1600
It just means that it is not not registered to work with windows by microsoft.
The manufacturer doesnt have to work with Microsoft to make their products work.
If possible you can go ahead with the installation. To be safe set a restore point before doing so, though
Jan 12, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wintv 2000
From the Hauppauge website:
Error Messages when attempting to run WinTV32 or WinTV2000:
Error messages such as: "Error. Cannot locate capture filter", "Cannot build filtergraph", "Error connecting Vcap and HCWCap filters", "Error connecting preview pin" can be caused by bad driver installations. Run the latest driver on the Hauppauge WinTV-USB technical support page to fix this. This new driver runs HCWCLEAR first, and then automatically reinstalls the driver.
Aternatively you may receive an 'Initialization error HTV=## '. Please look in the Device manager to see if the Hauppauge WinTV USB is listed correctly in the Device Manager. If it is not listed properly or if it has a Yellow mark on it, the drivers should be reinstalled.
Also, look under Universal Serial Bus controllers in Device Manager and be sure that the "Universal serial bus controller" is listed correctly(not disabled) as well as the USB root hub. If disabled, re-enable, and reboot.
Jan 02, 2008 | Hauppauge WinTV-Go Plus (85428010335) TV...
I get problems loading my instalation disk .
try and go to the manufacturers website and downloading the latest drivers from them. Sometimes they have trouble with the drivers on the cd but obviously can't recall every cd, so they release the updated drivers online through their website.
Nov 20, 2007 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
69 people viewed this question
Top Hauppauge TV Accessories Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Luc Francoeur
Luc Francoeur
Are you a Hauppauge TV Accessory Expert? Answer questions, earn points and help others
