Question about HP Pavilion dv9700t Notebook PC
I have a hp dv9700 video controler problem on xp i need to install the correct driver for xp
Driver audio hp dv9700 xp
Hello visit HP here:
http://h10025.www1.hp.com/ewfrf/wc/siteHome?cc=us&dlc=en&lc=en&product=3636841
And enter the product number, from under the pc.
You will have to select your windows system, when you find the pc model.
You can also try the auto find function, by installing a small bit of software.
Good luck
Apr 13, 2013 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Webcam not recognised by HP dv9700 laptop
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Dec 23, 2012 | HP Pavilion dv4170us Notebook
Video controller driver for xp os on hp proliant ML110
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=proliant%2520ML110&searchtype=s-002
Apr 27, 2012 | HP ProLiant ML110 Server
I cant hear anything on my hp pavillion dv9700 laptop. how do i fix it.
You need to install your sound driver. Ig you fo to this HP website below there you will be able to find and download your sound driver and audio manger too.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?product=3636841&tmp_qt=driver&tmp_product=HP+Pavilion+dv9700+CTO+Entertainment+Notebook+PC&lc=en&dlc=en&cc=us
Once installed ensure the speaker is plugged in correctly,and not Muted.
Jun 18, 2010 | HP Pavilion (PN153AAR) PC Desktop
Which graphic driver is suitable for xp
Hello, You need to find out what model you Nvidia is.(look in your manual or look for it under or on top of, your laptop, its a taq)
then go here and choose your graphic card.
download and install.
It should be helpful if you gave me the exact model of your computer.
Aug 17, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Nvidia graphic driver problem
Sir,
This is the problem with XP. Your nvidia graphic drivers is not supported by XP. So go to manufacturer's website and download the appropriate driver for XP.
Thanks
Good Luck
Downgrading HP9500 Vista to XP Video Driver problem
go into ur control panel and use ADD NEW HARDWARE...run ur appilcation from here shold give u results use disc if u have one..in order to get all cataylist drivers for nvidia u might need to go to nividia supportcom for all latest drivers
Jul 18, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
No audio from HDMI on HP Pavillion DV9700
If you are not getting any audio through the laptop without the hdmi cable check that the volume control has not been turned down on either the laptop or on the windows volume control icon in the bottom right corner of your screen. Sometimes the easy solutions are the hardest to find.
Jun 10, 2009 | HP Pavilion dv9000z Notebook
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
218 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
