SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: how do you program channel and set time on clock?
2001 - 2002 Models:
Press the "CLK" (clock) button until the time is displayed, then press and hold the "CLK" button for at least 3 seconds until the time indicator blinks.
While the time is blinking. turn the rotary encoder to increase or decrease the minutes.
Once you've set the clock it will automatically return to normal operation after 5 seconds.
Pre 2000 Models:
Press and hold the "CLOCK" button for 3 seconds until the time indicator blinks.
Press "PRESET 5" to adjust the hour setting.
Press "PRESET 6" to adjust the minutes.
Press "CLOCK" again to exit clock adjustment mode
Hope this helps.
And to set the stations get the station you want and hold down one of the buttons from 1-6 to progream the station. you need to hold the button for about 5 sec.
SOURCE: Clock and date troubles - Acer Aspire 5680
Richard the RTC battery needs to be replaced.
Real Time Clock battery. This is just like a CMOS battery used in a desktop computer, but the small round, watch style battery, (CR2032) is in a 'pouch' like holder.
The holder is a little bigger than the battery itself, and looks like a plastic pouch with two wires coming out, to a small white plug.
It's located under a bottom panel cover of the laptop. Certain screws have to be removed to remove the panel, then you can access the battery holder. (AFTER AC adapter, {Charger}, and battery has been removed FIRST! Also you have to work on a table, and should wear an anti-static wrist S T R A P. Connect the alligator clip to a good ground source)
I realize this may all look like I'm typing a foreign language here, so I would like to give you this link for an Acer Aspire 5762WMLi.
The information is in a forum, and it is two photos that I'm referring to. The info in the forum concerns resetting the BIOS, but I just would like you to view the photos, not the BIOS resetting information,
http://forum.notebookreview.com/showthread.php?t=40292
The two photos are at the bottom of the page.
SOURCE: I am looking for instructions on how to change the
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Fossil watch manuals. Rate me, plz.
Testimonial: "Response was prompt (within hours)and very helpful. "
