Network controller i have problem when i see at view system,thats problem is network controller
Cant get on the internet
If you have win xp operating system then you can follow instruction to resolve your issue
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
hope this will help you
Thanks for using Fixya
Jun 12, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
Tip
How to show/hide your Network Connection icon in the Windows XP System Tray 1....
1. You will need to open your Control Panel. Note there is several ways to do this.
XP Start Menu it is on the right side of the start menu.
Classic Start Menu it is under Settings
2. Next you need to make sure you are in classic view. Note if you have not been in Control Panel before you most likely will not be in classic view. To put Control Panel in classic view click on the Classic View option in the upper left hand corner.
3. Now Control Panel should look something like this. Here is where you would click on Network Connections.
4. Right click on the network connection that you want to change the option on and select properties.
5. Making sure that you are on the General tab at the bottom of the window you can check or uncheck the option "Show icon in notification area when connected"
6. After you have made your changes click on the OK button and the window will close.
on Feb 23, 2011 | Computers & Internet
Tip
Viewing Your IP Address Information
There are several ways you can determine your IP address information:
IPCONFIG
  1. Start / Run / cmd
  2. IPCONFIG /ALL
This opens a command window. One advantage is that you can send the information to a text file (IPCONFIG /ALL > c:\ip.txt)
But sometimes the window shows show much information you need to scroll around to fine it.
VIEW STATUS
  1. Control Panel / Network Connections / Double click the icons for your network (If the network has an icon in the system tray you can also just double click on that icon)
  2. Click on the Support tab
  3. Click on the Details button
on Sep 20, 2010 | Computers & Internet
I have a printer on my desktop but i want to print
Click Start
Click Control Panel
Click Classic View
Click Printers
Right-mouse-click on your printer
Click Share This Printer
In Control Panel, click System
Click Computer Name
Click Change
Pick a name for your work-group.
On your laptop, access Control Panel, and click System
Click Computer Name
Click Change
Enter the same name that you picked, above.
Now, both computers are in the same workgroup.
On the laptop, access Control Panel.
Click Network Connections.
Click My Network Places
Click View Workgroup Computers
After a few seconds, you should "see" your desktop computer's name..
Click that icon to find the "shared" printer.
Now, your laptop can print to that networked printer.
Nov 19, 2009 | HP PSC 1315 All-In-One InkJet Printer
Where is on switch for wifi button??
a lot of computers, like myne for instance, use a proram either natve to the computer like wndows, or something like intel PROSET wireless. i would recommend doing a computer search for these or other programs like these.
Nov 13, 2009 | Gateway 400SD4 Notebook
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Tip
How to connect to a wireless network with windows xp (must have a wireless...
  • In the start menu, click "Control Panel"
  • In the Control Panel window, click Switch to Classic View. If the text reads Switch to Category View, then you are already in Classic View and can skip to the next step.
  • In the Control Panel window, double-click Network Connections.
  • In the Network Connections window, right-click on the appropriate wireless network connection, and select View Available Wireless Networks.
  • In the Wireless Network Connection window, select your Wi-Fi (SSID)"Connect".
  • If you don't have a security code on it then In the Wireless Network Connection warning dialog, click "Connect Anyway" .
  • The Wireless Network Connection window will first indicate a status of Acquiring Network Address for your Wi-Fi, and a few seconds later will indicate a status of Connected. You are now connected to your router and can close the window.
on Jan 18, 2010 | Computers & Internet
HPDV7-1267CL LapTop
Hi raji767. You left out a few important details such as which operating system you are using and if the WiFi signal you are trying to connect to is encrypted. I will try to give the best step by step instructions I can based on the info you gave. I am assuming you are using either Windows XP or Vista. First, make sure the wireless is turned on. There is a button on the side by the headphone jack which turns the wireless on and off.
WINDOWS XP: Click Start, Control Panel. On the left side of the control panel window you should see "switch to classic view" or "switch to category view". To make it easy, make sure you are in classic view. Next double click the icon labeled "Network Connections". Next, right click on the "Wireless Network Connection" and select "View Available Wireless Networks". In this window you should see the network you are trying to connect to. Next just select the network and click connect. NOTE: If the network is encrypted, you will need to enter the key after pressing connect.
VISTA: First, go to "Start Menu", "Control Panel", "Network and Internet". Next, go to "Network and Sharing Center" and select "Connect to a network". Choose "Show All" and hit the refresh button. Now just select the network you want to connect to and click connect.
Hope this helps. If you have any questions just let me know. Good Luck!
Aug 23, 2009 | Cisco CAB-OCTAL-ASYNC Serial Cable HPDB68M...
Networking
control panel > view network and internet > network sharing center > manage network connection
Feb 03, 2009 | Microsoft Windows Vista Home Premium with...
Network Problem
SETTINGS FOR SYSTEM THAT YOU HAVE INST. VISTA
Create a new user for as adminstrater rights.
Go to control Pannel --------> Network & Internet -----------> view network status and tasks------------> shairing & discovery---------> public folder shairing----------> (2) Turn on sharing anyone with network option can open, change and create a file. ----> apply
If your other PC asks for Password & usename enter usename which you just created.
Feb 20, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
565 people viewed this question
David Payne
David Payne
