Question about Magic Chef CER3725AA Electric Kitchen Range
Clock now shows an SA6 error code
I was trying to reset the time and all of a sudden the SA6 error code appearred. Now the oven no longer works and this week is Thanksgiving.
What does this error code mean?
I can't find a manual on the internet.
  • ehoyer Nov 20, 2007
    I just got done talking to customer support. This mode disables everything but the cooktop. I put the oven there by holding the Clock button down for more than 3 seconds.
    They helped me restore the oven by holding the clock button down for more than 5 seconds. Once I let go off the button, everything returned to normal and the problem was solved.
Hold down the clock key for more than 5 seconds, did the trick!
Posted on Jul 08, 2008
  • Timothy Hornby
    Timothy Hornby Nov 02, 2014
    that worked perfectly.
  • 248 Answers
Sounds like you somehow put it in Sabbath mode. What it's saying is "Sab". Look in your book to see how to disable. Think it might be by holding down "6" key for 10 seconds. But not sure. Look in your owners manual.
Posted on Nov 20, 2007
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
Stove works oven wont turn on. now is reading fault code (SA6). what does that mean? and how do I fix the proble
If sab Push and hold clock button in for a few seconds.When it clears, the oven should work fine. God-Bless! Just let me know if that works. It is in sabbath mode. Research said it is sab not sa6,
Dec 28, 2015 | Maytag Range Oven Part - Oven Temperature...
How to clear or reset SA6 code on digital display? none of the button function works.
SAB (which is probably the display message) means that the range is in Sabbath mode. The unit believes that you want the range to maintain whatever the previous settings were for the next 24-36 hours. (This is useful for those who do no work on the Sabbath but wish to keep a dish hot in a low oven for the period.)
Providing the model number would be more helpful than the serial number. The manual for the range will explain how to toggle on and off the Sabbath mode. Since you don't give your range's manufacturer and model number, I can't be sure how to disable the mode. However, on some models, press and hold the Timed oven "Cook Time" and "Delay start" buttons. For some Maytag ovens, just press and hold the Clock key.
I hope this helps.
Oct 20, 2015 | Kitchen Ranges
F1 code on GE Profile Range. Model # JGSP40AES2AG Oven Sensor checks 1100 OMHS at 79 degrees and drops to 980 when cooled in 66 degree water. Oven temperate is maintained when oven is used. F1 code...
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the electronic control/clock assembly. You can try ebay for a new part and check this video for repair:
Please get back to me if you have any other questions.
Apr 15, 2011 | Ovens
This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
Mar 06, 2011 | Kenmore 46564 / 46565 / 465 / 6646569...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag oven - error message sa6. oven wont work. stove top works
If you are receiving the SAb code your range is in the sabbath mode. I don't know what this means but it is really easy to fix. Press and hold the clock button for 5 seconds. The code will flash, let go and it is reset.
May 04, 2008 | Maytag Kitchen Ranges
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Magic Chef CER3725AA Electric Kitchen Range Logo
1,026 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
