Duo Therm AC/Heating not working at all after tripped breaker.
I have a Duo Therm AC/Heating unit that came with the RV. About 12 yrs old. The RV is parked at a ranch and the breakers were tripped (main and ac) I turned them back on and every thing works but the ac unit. I cannot even get the fan to blow. I have looked everywhere for another breaker and did not have a volt meter with me. Going back out this weekend. Any ideas would be helpful.
    Problem Solver:
  • 17 Answers
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Posted on Jul 20, 2009
Dometic Duo Therm RV AC makes clicking noise when turned off
The braker is getting weak and needs to be replaced the act should be cleaned as the coils get dirty and make the units work harder
Jul 19, 2014 | Dometic Heating & Cooling
Duo therm mod. 57915 air conditioner seems to work good , runs for 4-5 minutes then kicks breaker , was kicking 30 amp breaker at camp ground , i've been working on connections to make sure its...
Unit may pull as much as 17-18amps when compressor starts up, but level out to 12-15 amps when up and running. Keeping in mind that is all relative to proper 120v incoming voltage, heavy enough wire to run the application etc. If your AC unit needs cleaning , it may draw an extra amp or 2 . With that said, when your at the park, first thing I'd question is their incoming voltage to RV, and try running fridge etc and anything else on propane if possible. The AC alone should not cause 30amp at source breaker to trip, before 15 0r 20 amp breaker in RV that is connected to AC trips. If it doesn't trip your breaker at home, and all is connected same at park, then I certainly would suspect bad breaker or voltage/wiring at park is the cause. P.S. I noticed you said you have 12 gauge wire (rated at 20 amps) connected to a 20amp breaker at panel, but RV is plugged in to a 15amp receptacle, I will assume with a 15 amp adapter from 30 amp plug. Do you see any hazard regarding 15 amp rating on receptacle? ( just a little advice.)
Aug 15, 2011 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
246 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
