Question about Acer Computers & Internet
Motherboard is bad - Acer Computers & Internet
    Master:
    Sergeant:
  • 226 Answers
If the motherboard is bad just replace it
Posted on Jul 20, 2009
Think cpu is bad cpu fan looked up
Replacing the bad caps and fan may fix the problem.
My guess - you need a new motherboard/computer.
Feb 01, 2013 | Jetway V266B Motherboard
I had two asus m2n-mx mother board with Athlon AMD 64X2 processor. As one of my motherboard was not working so i decied to check my faulty motherboard-1 with my working Processor-2. The motherboard-1 was...
did you say that you swapped a cpu from a working motherboard to a bad motherboard and now they are both bad? did not fully understand your problem.
Oct 27, 2010 | ASUS M2N-MX Motherboard
The ECS C51GM-M Motherboard problem is that the fans turn but no video, no post, no bios.
This could be due to many things. One is a bad power supply. Any peripheral that is bad could cause it. Your memory could be bad. I would unhook every peripheral/hardware but the video cable, memory, CPU and keyboard/mouse. If you get video then one of the other things are bad. For instance, I have found that a bad CD will prevent a system from booting.
If you have no luck, then the problem lies in the motherboard, memory, or CPU. To eliminate the memory possibility, take one stick of memory out and try it.
Sep 11, 2010 | ECS C51GM-M Motherboard
Everything was working fine but now there is no beep sound when starting and no bios
If there is no beep then your computer isn't even running the POST (Power On Self Test). That pretty much mean a bad power supply, bad switch or bad motherboard.
Jun 30, 2010 | AOpen MX34 (91.88510.101) Motherboard
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
What can cause the motherboard on the roland sp-300v to go bad? no connection to the printer.
It could be a "bad" power-supply feeding "bad" power to the motherboard, or not feeding any power to the motherboard.
Try a different power-supply.
Take a close look at the motherboard.
Those "pencil-eraser" things are capacitors.
If you see any brown-coloured dust on top of any of them, the capacitor is leaking.
If you see any "dome" on top of a capacitor, then it is going bad.
Is it still covered by the manufacturer's warranty?
Aug 13, 2009 | Computers & Internet
On boot up ,during 'post' the laptop (acer 5100) beeps twice(2 short beeps) and advises that there is a resource conflict. It then advises to press f1 to continus loading windows and promptly hangs! Any...
Resource Conflict - PCI in slot 02, Bus:01, Device:09, Function:02 Does It Read Something like this? If that is correct, you might not have all of the drivers for your hardware installed. Find out who your manufacturers are and download/ update your drivers.
Apr 24, 2008 | Computers & Internet
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
