Question about Dishwashers
Dishes are not getting clean..glasses are covered in crud
  • 227 Answers
Try refilling the rinse agent, and cleaning out the bottom of the unit. If the dish washer was resently installed. Or you have recently intalled or replaced your garbage disposal. Make sure the plug was punced out where the drain from the dish washer connects. If the plug is not punched out you will be useing the same water over and over agian.
Posted on Jul 20, 2009
Glass and Glass cups or Plates come out dull, like covered with thin limestone powder .
I suffer the same issue it was only fixed by upgrading the washing tablets used
Oct 19, 2012 | AEG Favorit 50500 Built-in Dishwasher
Dishes in the upper rack no longer get cleaned. I've been using this dishwasher since 2004 (purchased new), and have not changed the way I loaded the dishes or the detergent. I called the Kitchen Aid help...
It may be full of crud under screen. Remove lower spray arm, tower up to top, covers and you will see where the entrance to the impeller is full of stuff.
Oct 28, 2010 | KitchenAid Dishwashers
Etching on the glass ware and the dishes don't come clean.
Dishes may not be getting enough rinse water. Had the same problem before I replaced inlet valve. My fisher packel was 3.5 years old before I replaced the inlet valve due to a knocking noise, but It still ran through cleaning cycle without any alarm codes.
May 17, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
There is baked on crud in the glasses after the cycle is over. I've cleaned the screen at the pump because it is clogged,and that fixes it, but it gets clogged again real soon. I also replaced the litle...
Run the washer on some empty cycles with the cleaning solution/powder/tablets you usually use. Also rinse the dishes etc before you put them in the washer
Nov 03, 2017 | Kenmore 16919 Built-in Dishwasher
Salty white dishes
Pour white vinegar into the rinse cycle, this should help.
Apr 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes aren't getting clean, especially glasses on the top rack
check chopper remove bottom spray arm remove 4 screws take of cover then 2 more screws and the chopper is there.probably broken
Nov 21, 2008 | Kenmore Dishwashers
Bits of food on glasses
I have the same problem, and sometimes, when I add salt to my water softener, the problem goes away until the next time I need to add salt. Other times, I have no idea when I'm going to have the crud in the glasses. I've tried different detergents, rinse agents and even different shaped glasses. Seems the glasses which have slightly larger bottoms than tops are worse.
Sep 02, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
May 05, 2008 | Kelvinator MDB121RF Dishwasher
I have a maytag mdb4000aww dish washer. The dishes aren't getting consistently clean. I wanted to clean the trap/filter. There's two ports towards the front side. The one on the right i was able to...
Hi
The port on the left is the float it has no filter don’t try to remove it. To get your dishes cleaner: step one, each time you wash run the tap water in your sink till it’s hot. Step two, buy what’s called “dishwasher magic” use that every 2-3 months. Three, use rinse aid. Four, check the sprayer arms, make sure all the holes are clear and that they spin freely when the dishwasher is loaded. There is the possibility that the interior motor area needs to be cleaned, if you’re handy you can remove the lower spray arm and the cover, lift that up to expose the interior motor area, this is fairly involved, if you’re not comfortable you should call for repair, it shouldn’t cost too much.
Apr 01, 2008 | Dishwashers
Dishwashers Logo
161 people viewed this question
Top Dishwashers Experts
