Question about Craftsman 10" Table Saw
Reduced RPM and smell smoke
After reaching max rpm, it begins to slow down and can smell electrical smoke.
  • 2,176 Answers
Could be electrical problem, (brushes burnt, armature grounded or bearings starting to seize up) I don't think that I would use it till the problem is fixed. Could cause or create more expensive repair. Let me know and I will try and help
Posted on Jul 20, 2009
Navara 2.5 diesel only reaching 2,000 rpm
Blue smoke is oil. Compression check. and check plugs for fouling.
Apr 26, 2014 | 2005 Nissan King Cab
2000 toyota tundra slow to accelerate, will oly reach 10mph in drive.---- run good in reverse
what is max rpm on engine, at 10mph ?
that is the KEY question. and solves
bad engine
bad tranny
and is first, after checking all fuses. always.
Feb 03, 2014 | 2000 Toyota Tundra
Messed up carburetor
Start out with both screws at 1-1/2 run saw full throttle and adj. screw closest to air filter, which should be "H" screw it in slowly till you reach max rpm's then reverese the screw just till it starts to slow down, keep in mind don't take forever to do this cause you don't want it running lean (max rpm's) because it will COOK in no time! After you have the high speed set let saw Idle, then accelerate quickly, if it bogs turn the "L"" clockwise little at a time reving it each time, till you get the bog worked, then when acceleration sounds quite responsive then go back to H speed and readjust it, open it up some and run it wide open and readadjust H speed to where it just drops off on rpms on the rich side not lean side, righty (leany)...Lefty Richy ! Good luck
Dec 09, 2011 | Poulan Garden
03 Mazda Tribute's charging indicator light begins flashing on and off when engine reaches 1200 rpm and becomes contineously on at and above 1500 rpm. With engine idling or decelerating to below 1200 rpm...
It may be that the light is being tripped due to an "over voltage" condition. The faster you spin the alternator/engine the higher the voltage output of the alternator. I would test the voltage coming out of the alternator. It should be at about 14.3v or so max. If it gets into the 16v+ range when you increase the engine RPM then the voltage regulator has failed and needs to be replaced.
Feb 03, 2011 | 2003 Mazda Tribute
Motor may be burned out
Any time an electrical motor burned out, a smoke clound come out and a very unpleasant smell come out. If you did not anticipate the above then look for problem elsewhere.
Dec 23, 2010 | Toastmaster Food Mixers
Once car reaches speed of 100 it begins to
sounds like it has a govoner
take to dealer and have diag done
Mar 26, 2010 | 1997 GMC Jimmy
Ford accereration problem
sounds like you egr valve is faulty does your eng light come on.
Apr 10, 2009 | 2004 Ford Focus
Electrical system acting up at high RPM
halogen headlight taillight/brake light turn signals odo/speedo and horn. Here are the problems… Above about 6000 RPM the ignition will intermittently cut out. It doesn’t do it all the time. The higher the RPM the more it tends to cut out. Reducing RPM brings the lights back to bright. Above about 6000 RPM the lights start to dim intermittently. The higher the RPM the dimmer they get to where the lights almost go out. The engine runs fine if the RPM is reduced. The tachometer records some very high RPMS when the system starts to act up. Max RPM recorded is 19999 which is totally unreasonable. I am looking for some assistance in troubleshooting my electrical system and how to isolate the problem(s).,Start by disconnecting the cables from the generator coils and start up your engine. Problem still there? Do this to find out if your problems stems from the power side or the ignition side. If bike now runs fine, I'd look at the voltage regulator. Have you checked that all your connectors are ok? A grounding problem with a somewhat loose connector would be vibration sensitive, hence the problems at higher rpm. Is your stator plate securely fastened? Is your engine grounded to chassis? There might be a loose fastening in one of you engine mounts. Reply With Quote,,,
Nov 10, 2008 | 2000 Gas Gas EC 300
Craftsman 10" Table Saw Logo
336 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
