hi
What The Code Means. For those that want to know, the 2F1F error means the recovery system has been driven but no sensor interrupt occurs. The recovery system has been driven to close the cap, but the cap has not been capped successfully.
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader. If your computer doesn't have a built-in card reader then you can buy an inexpensive reader that connects to your USB port. This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Those cant be cleaned from outside! The cleaning procedure is alwasy from the inside by help of the original ink (which contains additives of special cleaning fluids). This is due to the very special technique of electro-piezo ph instead of bubblejets (canon system) which can be cleaned sometimes from outside.
Another fact is that due to the tube (capillaries) system its quite often possible that air bubbles have grown when transported from refilled carts to ph. This air bubbles prevent the nozzels to work well or itz seems to the user that the channel is clogged.
Some advice to generic ink: do refill original carts only. This is because of several reasons (prevent staining, malfunction and more trouble). Buy refill DYE-ink (universal ink from jettec or inktec work excellent) and some glycerol (85%- glycerin alc.) at the drugstore. Mix 2ml glycerol with 10ml of C/Y/M ink very well and refill the C/Y/M carts with that: drill a hole of 2mm into the top of the cart (e.g. O of brother brand name). For bk mix 1.5ml glycerol with 15ml bk dye ink and shake very, very well before refilling the cart.
So here is what you can do to get rid of the clogging: Plz use 4 new, full ORIGINAL brother carts (quite costly, I know).. Place them in and make sure they are secured. Press menu then start bk then fourtimes arrow up. machine will be in maintenance mode. press 7-6-4 then start bk copy. machine will initialize the carts, by refreshing ink in tubes and ph, delete air bubbles and do some power cleaning. when finished press 7-6-3 then start bk copy. Machine will do an extra power purge.
when finished leave maintenance by pressing 9 then 9. Do a test print after machine comes up again. If your lucky your generic ink hasnt destroyed the ph! Otherwise you need a new mfc due to the fact, that a ph is very costly!
BTW: Be very carefully when clicking the ph cover back into position! Wachtch the upper leftside: dont break the small platic guide which leads the ph on the rail.
And...
to delete error A1 (scanner top open) simply make sure, that the top is in right position ;-) (If you have read out the error code from maintenance as an error: this is NO error! Its in info which have all brother printers when the scanner is opened the first time ;-)
the fixya message systems fools my email account since half a week. So, I m sorry, that I cant answer straight to your requests...
Now lets have a look at your prob:
First things first for brother ph:
And...
To reset the 'MT CARTRIDGE FULL SOON' error. Enter Service mode Hold down the paper source and online button at the same
time, hit the power button once.Continue to hold down the paper and online buttons until you see the printer name "Canon W6200"
on the printers LCD display, then release the two buttons.The
printer will initialize & enter service mode. In service mode, scroll sideways until you see the 'Initialize' menu, scroll down to 'W-ink', and press enter. At this point I did something (scroll sideways and hit enter I think) and it came up with 'New W-ink Cart' Hit Enter to get '=New W-ink Cart' and Online to Accept. I powered down and back up, error all clear.
