My friend was using a craftsman push weed eater and ran it out of gas! well he put gas in it that had water in it ! So i took it apart and cleaned it out but im having trouble finding where the cables and springs go ! I need a blown up pic of the out side of that motor so i can finish it
To fix a weed eater that won't start, check the fuel to ensure that you are using the correct gas-to-oil ratio for the weed eater. Then, you have to change the spark plug. After that, replace the fuel filter. Now, you need to review the starting process of the weed eater.
Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
