Question about HTC Touch Cellular Phone
My touch screen is broken and there is a password you need to use by drawing a pattern on the screen in order to unlock it. It will unlock if some one calls and I pick up after a few times, but after the phone falls asleep it locks again and you need to draw the pattern. Is there anything I can do without fixing the screen?
    Master:
  • 395 Answers
You must take it to a Cellular center where they have a computer to unlock the device. Once a Screen is broken, the entire phone is useless.
Posted on Mar 30, 2015
270rexton
  • 782 Answers
SOURCE: emergency calls only , cant get unlocked
go to communication and turn on radio.
Posted on May 30, 2009
270rexton
  • 782 Answers
SOURCE: I have a HTC touch pro. The password does not work!
try use the keyboard (and also make sure that typed button show correct symbol). If everything is in order, then somebody must changed your code.
Posted on Jul 23, 2009
SOURCE: i forgot my drawing pass code to my hero phone how
When you fail to draw the correct unlock pattern on the screen after five attempts, you will be prompted to wait for 30 seconds before you can try again. If you forgot your screen unlock pattern, tap Forgot pattern. You will be prompted to sign in using your Google Account name and password, and create a new screen unlock pattern before the Home screen displays
Posted on Dec 12, 2009
  • 211 Answers
SOURCE: forgot password to htc hero the google password
format the phone... download the firmware frm the HTC site and follow the instructions
Posted on Jan 10, 2010
  • 4 Answers
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is... hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S. Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure. Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
Posted on Feb 03, 2010
I want to reset my security pattern
on a car security, no idea, but on Android, this is how.
How to reset your Android screen lock security pattern ... TechRepublic Draw the pattern, click Continue, draw the pattern again, and you're back in business. You can also increase the security of your phone by setting it to lock ...
How to reset your Android screen lock security pattern TechRepublic
May 24, 2016 | Vehicle Parts & Accessories
Ascend y330. Where can I get free SIM unlock code?
http://sim-unlock.net/simlock/Huawei/Y330
How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
Nov 21, 2015 | Huawei Cell Phones
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
HOW TO UNLOCK HUAWEI CELPHONE
Hi, The safest method to unlock a Huawei Ideos X5 is to unlock using unlock code. An unlock code for a Huawei Ideos X5 can be obtained from www.superunlockcodes.com/huawei-ideos-x5/rs16wp9/ at affordable cost.
UNLOCKING STEPS FOR HUAWEI IDEOS X5
If your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
Oct 17, 2012 | Huawei Ideos X5
Android my touch screen locked
Did you set some pattern to unlock the screen? If yes, then after drawing wrong patterns 5 times (or may be 3, please try both), you will be prompted to enter your google credentials. Enter that & it will be unlocked.
Jul 20, 2012 | Android Apps
I have a bluechip android phone,my son locked it,it says i need my google account user name and password,wnich i dont know because i have never needed it
This is a common problem, where you input the correct name and password and it still doesn't work. To solve this: Try going to this site from your PC: https://www.google.com/accounts/UnlockCaptcha Put in your info and it should say device unlocked Re-enter your info into your phone and it should take you to a new screen to set a new pattern and once you set it your phone should be unlocked. After you unlock your phone, you can take off the pattern unlock in the settings.
Apr 28, 2012 | Cell Phones
Unlock with google email
To unlock the pattern screen lock, sign in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. The user need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
Hope this help
Feb 17, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Locked out by too many patterns attempts it tells yo sign in my google account but i dont remeember my username and password please help me
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
Aug 17, 2010 | Sony Ericsson XPERIA X10 Cell Phone
I have locked my friend mobile of sony ericsson experia x10 screen now the phone screen saying ( to unlock u phone please enter u google account and password ). i have tried my gmail account and...
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
Aug 14, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Please i need to unlock my T-Mobile G1 mobile phone. How can you help me with remote unlock if i provide IMEI number.
Exactly how are you locked out? If you're stuck on the lock-out screen with a lockout pattern that you've forgotten? If that's the case, the G1 manual indicates the following:
"When you fail to draw the correct unlock pattern on the screen after five attempts, you will be prompted to wait for 30 seconds before you can try again. If you forgot your screen unlock pattern, touch Forgot pattern. You will be prompted to sign in using your Google Account name and password, and create a new screen unlock pattern before the Home screen displays."
Aug 21, 2009 | HTC G1 Smartphone
HTC Touch Cellular Phone Logo
208 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
