Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
Craftsman Miter Saw - can't remove the blade
I have an old miter saw and the blade nut is on the left side (when facing the saw). The lock won't hold and I am not sure which way to turn the nut to loosen it. I've tried both ways and used WD-40, but I still can't get it off. Any suggestions? Thanks!
  • 2,176 Answers
It is left hand thread and if the lock won't hold what you can try is put a 2x4 on the table and pull the head down against the wood and with a good socket and ratchet loosen it that way.. remember to tighten to loosen
Posted on Jul 20, 2009
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Sep 10, 2010 | Makita 10" Miter Saw LS1030N
How to change a blade in a sears 10" compound miter saw
there should be a spindle lock on this tool, lower the blade guard without removing and hold the spindle lock and the screw is usually left hand thread.
Aug 31, 2010 | Craftsman Saws
HOW TO CHANGE BLADE
Do you have the wrench that came with the saw? It should be slid in the back somewhere, there is a lock on the top that you hold the motor locked with, unplug the saw, turn the nut on the blade, start the saw down and grab the guard with your thumb to hold it and then lift it up all the way to slip the blade out. You should be all set.
Jun 20, 2010 | Makita 10" Compound Miter Saw LS1040
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Need to change the blade on a craftsman 10'' miter saw model 137.23498, how do i do it?
First off, unplug the saw. No need to remove the guard, though you may have to loosen the cover over the lock nut to access it on some saws.
Look for an arbor lock button on the back side of the blade housing or motor, to lock the blade in place.
Hold that down and use a wrench to loosen the nut holding the blade on.
If you don't have an arbor lock, you'll have to wedge a 1x 4 or 2x4 under the blade and hold pressure on the handle to keep it from spinning while you loosen the lock nut. Once it's loose, spin it off and remove the washer and blade, replace and retighten the nut.
Should be pretty straightforward, as long as you have no power to the machine and lock the blade from turning, not too much can go wrong.
If you want to find an online manual with instructions for your saw, please try Sears online support site at www.managemyhome.com.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 14, 2009 | Craftsman Saws
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
1,045 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
